HELP !!!!! motor swap help
ok i have a 1992 honda prelude si had the h23 no vtech dual overhead cam motor in it. I blew it up and some1 gave me a free f22b1 vtech single overhead cam motor out of a 1994 accord and so i put it in and i used the wiring harness factory wirening harness and i also used the butterfly off the h23 and the injectors out of the h23 now....i can get it to run but only if gas is bein squirt into it once you stop squirting it into it the car then dies...the guy who is actually working on the car says there is a plug he thinks is to tell the injectors to put gas in the car put its not plugged up and there in nothing i can find to plug it into...can some1 give some answers on how to make this thing run...do i need to switch harnesses or computers or can i bypass some plugs or anything
You will need to swap ecu's and those injectors are the wrong size, you need to get the correct size and make sure to get peak and hold injectors in stock size, or bigger if you have a way to tune them in.
rmiller
Feb 2, 2008 09:58 AM
