FS: 5zigen wheels/tires, BBK 70mm throttle body/TPS/gasket, silicone hoses, more!!!
WAY MORE STUFF IN SECOND POST!
(5) good 5Zigen RSX-6 wheels with BF Goodrich G-force Sport tires
-Wheels are 16x7" hyperblack in color
-Tires are 205/45/16 Z rated (less than 8,000 miles, no camber wear)
- No curb rash at all, some small chips
-5th wheel has no tire, and has a lot more scratches but is straight
-5th wheel is perfect for a full spare, just throw a cheap tire on it!
-Chrome valve stems/locking lug nuts included
-Discontinued a while ago
-Discount tire warranties for all 4 tires
Neuspeed Front Upper Strut Bar-Black (non-ABS only!) $100 SOLD
Skunk2 Rear upper strut bar for a DA, no mods to fit $100 SOLD
BBK 70mm throttle body with Omnipower TPS and P2R heatshield gasket $200
OBX red silicone radiator hoses- checked for leaks, there are none $50 SOLD
DC2 GSR gauge cluster swap complete with Electronic VSS from an accord, DC bezel, GSR cluster, and wiring plugs. Wiring diagram is also included!
I gave a few pictures of the wheels on my two different cars that I have owned, and all three colors that I had the cars. I never see these wheels anywhere, and get compliments all the time.
da_integra_tuner at hotmail . com
thanks, best offer on everything! car has been sold so i no longer need this stuff.
More stuff:
Just want to get rid of all this, make an offer and I will probably accept it.
1- OEM rear sway bar with brackets, bushings, end links, etc.
2- Hood release cable
3- Hood latch assembly
4- Complete stock intake system (tube, air box, filter, resonator, hose)
5- Radiator stay brackets
6- Under hood fuse box with all fuses and stuff
7- Under hood cruise control module
8- Power steering pump
9- Set of flywheel bolts
10- Set of (4) LS PR4 pistons and rods
11- OEM coil
12- Engine stabilizer brackets
13- Both alternator brackets
14- (2) Cable VSS sensors
15- Set of LS camshafts
16- Front brake calipers (L & R)
17- PR4 ECU for manual 90-91
18- ABS control computer for 90-93 integra
19- Front upper control arms with OEM ball joints
20- OEM Intake manifold
21- OEM "black box" for PCV system
22- Set of OEM valve stem seals
23- Complete thermostat housing
24- (2) OEM Honda thermostat gaskets
25- Transmission service cover
26- All four OEM 90-91 integra motor mounts including transmission bracket
27- (2) power steering upper brackets
28- Set of rear OEM "camber arms"
29- Black ash tray- non smoker
30- OEM pressure plate with less than 5k miles
31- Prothane rear motor mount insert
32- FITV
33- Fuel pump
34- ACL main bearings
35- Tuner toys oil line fitting kit
36-All interior switches (cruise, fog lights, hazards, mirrors, defroster, dimmer)
37- BOV flange adapter to use turbo XS BOV on a Greddy flange
38- New 9004 GP thunder bulbs, these are great, I had another set on my old car and loved them. These are a new set.
39-OEM resistor box
40- OEM oil pan plug gasket
41- OEM fuel pressure regulator gasket
42- Marshall liquid filled fuel pressure gauge
43- Complete engine timing cover set
44- EGR gasket
45- Alternator belt- new
46- Good blower motor
47- Manual pedal setup
48- OEM head bolt set
49- Insulated intake manifold gasket
50- OEM fuel rail insulators with new studs- perfect for skunk2 manifolds that don't come with them
51- Seatbelt control module- fix the beeping or non-functioning seatbelts!
More stuff:
11- OEM coil
32- FITV
33- Fuel pump
39-OEM resistor box
44- EGR gasket
They are for a b18a/b and a 1990-1993 integra. They are sold though. thanks!
I can probably find a way if the price is right and you pay the shipping. I would imagine it will be $150 or so for all of them. let me know!
Weird you got an error message, I have been getting PM's fine, maybe try again?
Thanks!
Thanks!
Sprockets
Northeast (Sales)
Jun 4, 2018 02:31 PM
edspecR
Northern California (Sales)
May 22, 2017 11:44 PM
