new CR-V some quick questions
hi guys, long time honda owner, first time CR-V owner, i also own a 92 prelude and absolutely love the thing!
this is now my new winter/DD car its a 1998 automatic
i just gave it a tune up, included spk plugs, wires, fuel filter, air filter, pcv, injector clean, intake clean, distributor cap and rotor, oil change, and transmission fluid change.
how many qts of "dual pump fluid" does the rear end take?
MY MAIN QUESTION is there any recall's. service bulletins, or very common things that break on these that should be fixed soon?
cool V you got there!!
the dealer told me to get(sold) me two bottles/quarts for our rear differential..
i only used dual pupm fluid from honda, no other fluid will work on it,
thats what has been discussed in some forums..
good luck!
Honda Dual Pump System Fluid II:
P/N 08200-9007, H/C 8632044
or just check with your local dealership
good luck!
RECALL NOTICE SUMMARY
AMERICAN HONDA MOTOR CO.
02V120000,
MFR
4/18/1996-8/1/1998
6/14/2002
1997-1999 ACURA CL, 1999 ACURA TL, 1997-1999 HONDA ACCORD, 1998-2000 HONDA
CIVIC, 1997-1999 HONDA CR-V, 1997-1999 HONDA ODYSSEY, 1997-1999 HONDA
PRELUDE, 1998-1999 ISUZU OASIS
21000000
ON CERTAIN SEDANS, COUPES, HATCHBACKS, AND SPORT UTILITY VEHICLES,
ELECTRICAL CONTACTS IN THE IGNITION SWITCH CAN DEGRADE DUE TO THE HIGH
ELECTRICAL CURRENT PASSING THROUGH THE SWITCH WHEN THE VEHICLE IS
STARTED.
WORN CONTACTS COULD CAUSE THE ENGINE TO STALL WITHOUT WARNING,
INCREASING THE RISK OF A CRASH.
DEALERS WILL REPLACE THE IGNITION SWITCH. OWNER NOTIFICATION BEGAN JUNE
14, 2002. OWNERS WHO TAKE THEIR VEHICLES TO AN AUTHORIZED DEALER ON AN
AGREED UPON SERVICE DATE AND DO NOT RECEIVE THE FREE REMEDY WITHIN A
REASONABLE TIME SHOULD CONTACT HONDA AT 1-800-999-1009 OR ACURA AT 1-800
-382-2238.
99V282000, K72
MFR
11/24/1997-11/18/1998
11/4/1999
1998-1999 HONDA CR-V
201782
VEHICLE DESCRIPTION: PASSENGER VEHICLES. AN IMPROPERLY ROUTED UNDER
DASH WIRE HARNESS COULD BE DAMAGED BY CONTACT WITH THE BRAKE LIGHT
SWITCH, POSSIBLY RESULTING IN A BLOWN FUSE. IF THIS OCCURS, OPERATION OF A
CRITICAL COMPONENT CAN BE LOST, INCLUDING WINDSHIELD WIPERS,
HEADLIGHTS, TURN SIGNAL AND HAZARD LAMPS, TAIL LAMPS, THE ANTI-LOCKING
FUNCTION OF THE BRAKES, AND BATTERY CHARGING SYSTEM.
A SUDDEN, UNEXPECTED LOSS OF LIGHTING OR A FAILURE OF THE WINDSHIELD
WIPERS IN BAD WEATHER, COULD BE HAZARDOUS INCREASING THE RISK OF A
CRASH.
DEALERS WILL INSTALL A 70MM PROTECTIVE, CORRUGATED PLASTIC TUBE OVER
THE WIRE HARNESS, IN THE AREA OF THE BRAKE STOP SWITCH. IF ANY WIRE OR
WIRES ARE DAMAGED, THEY WILL BE REPAIRED.
http://www.in.honda.com/Rjanisis/pubs/SB/A99-051.PDF
http://www.in.honda.com/Rjanisis/pubs/SB/A00-006.PDF
http://www.in.honda.com/Rjanisis/pubs/SB/A99-007.PDF
http://www.in.honda.com/Rjanisis/pubs/SB/A00-012.PDF
http://www.in.honda.com/Rjanisis/pubs/SB/A01-019.PDF
http://www.in.honda.com/Rjanisis/pubs/SB/A01-079.PDF
http://www.in.honda.com/Rjanisis/pubs/SB/A98-050.PDF
http://www.in.honda.com/Rjanisis/pubs/SB/A98-041.PDF
http://www.in.honda.com/Rjanisis/pubs/SB/A03-078.PDF
http://www.in.honda.com/Rjanisis/pubs/SB/A98-030.PDF
http://www.in.honda.com/Rjanisis/pubs/SB/A99-019.PDF
http://www.in.honda.com/Rjanisis/pubs/SB/A99-058.PDF
http://www.in.honda.com/Rjanisis/pubs/SB/A98-068.PDF
you have to drain out the dif fluid, add 1.5 quarts of the honda dual pump fluid and drive it around for a few miles makeing lots of turns and then drain it back out again and put in 1.5 quarts. this is what i did and my honda mech buddy told me to do it this way
agomez350
Aug 16, 2017 01:12 PM
psychoboy
Jun 2, 2011 09:18 AM
