Alarm wiring.
This is what my manual says. (-) Neutral Safety Switch Input. Connect this wire to the Park/Neutral switch in the vehicle. This wire will test with ground with the gears selector either in Park or Neutral. This input MUST rest at a ground in order for the remote start to operate. You may also connect this wire to the Parking Brake Switch. I have a 95 acura integra automatic if you can help with what wire it is.
aser1z
Dec 7, 2007 09:13 PM
