S2k OEM antenna Vs. S2k aftermarket antenna
Old Mar 17, 2009 | 01:06 PM
Devon M's Avatar
Default S2k OEM antenna Vs. S2k aftermarket antenna
For those of you with an S2k antenna conversion, which are you using? I can't seem to get my hands on an OEM one for less than $100. Is that the going rate? If I could get some feedback how the aftermarket ones look and work compared to the OEM that would be great. Thanks.
Old Mar 17, 2009 | 02:06 PM
vsmdc4teg's Avatar
Default Re: S2k OEM antenna Vs. S2k aftermarket antenna
Hit up www.locustom.com. I baught mine off there and it looks perfect on Integras. Called the Shark Attack II and its only $40. Id post a pic of mine but its on a non R integra
Old Mar 17, 2009 | 05:24 PM
Devon M's Avatar
I have seen these, thats what I have been comparing with the OEM.
Old Mar 18, 2009 | 12:57 PM
IanBlake's Avatar
shark attack II
this will help
http://www.team-integra.net/sections...?ArticleID=815
Old Mar 21, 2009 | 03:01 PM
Mike97LS's Avatar
They have changed the shark attack II in the last couple years and the base just bolts on and thats it. And to me it stands out and doesn't look right. I have the OEM S2000 in mine and it works like stock and reception is like stock. As it should be. TI's install is a little off on the OEM because the only thing you need is an O-ring thin enough to allow you to put it on like stock from the S2000 and not with the piece of PVC they show. If I remember right it is a Delta sink brand size 17. I used to work in a Hardware store for the first few years of college. And yeah, about $100 is the going rate for OEM. I paid about $120
Old Mar 21, 2009 | 08:13 PM
Devon M's Avatar
Well, I may have to suck it up and buy it one of these days. I have a BNIB OEM ITR one that I could sell to help offset the price.
p nut
Audio / Security / Video
Jul 10, 2008 06:57 AM
jdmSpectre
Sep 23, 2006 06:40 PM
