Brake Lights?
Old Mar 17, 2009 | 08:19 AM
toolbox21's Avatar
Default Brake Lights?
Alright When Push The Brake Pedal Down My Brake Lights Dont Come On, But When I Turn My Running Lights On The Brake Light Stay Lit With Them, I Checked Fuses Grounds No Luck? So If Anyone Has And Ideas In What The Prob Is OR Suggest What Exact Grounds To Check It Will Be Appreciated?
Old Mar 17, 2009 | 08:42 AM
JDMgunmetalCRX's Avatar
Default Re: Brake Lights?
sounds like its wired wrong to me.
maybe someone had wired them funky before u got ahold of ur car.
is it possible that your brake lights are actually wired to your parking lights?
i mean it sounds stupid but thats what it sounds like to me lol
Old Mar 17, 2009 | 11:58 AM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
If you screw the 1157 tail/stop bulb in upside down,
It will burn the tail and brake light at the same time
when the lights are turned on...
It doesn't really fit that way
but I have seem people force it in anyhow..
Old Mar 17, 2009 | 03:42 PM
detuned's Avatar
having this problem right now, lights are in fine. lights worked earlier today, now they're not working. the light in the hatch works fine though, just the sides don't light... checked fuses, wiring, etc etc. any light on the subject? heh.
Old Mar 17, 2009 | 05:04 PM
jacksonww's Avatar
Check the fuses under the hood.
I pulled the horn fuse under the hood to swap my steering wheel(I did not want it honking at me). When doing this I noticed when I pressed the brake pedal, the tail lights would not illuminate and my seatbelt warning and seatelt warning lights would come on. Weird if you ask me.
After putting the new steering wheel on then plugging the horn fuse back in... everything works fine.
Old Mar 17, 2009 | 08:31 PM
detuned's Avatar
fixed my problem. all fuses were fine, the problem was the sockets had seen the good old midwest humidity for 20 years and were rusted and corroded to hell. after some sandpaper and some new bulbs they work fine. wires and sockets need to be replaced, but electricians tape is just as good right now. hopefully this helps someone.
Nathan_volcom
Jan 30, 2009 10:00 AM
Adam.C
Mar 22, 2004 07:35 AM
crexer
19
Jul 18, 2003 02:51 PM
HatchBeezy
Jun 11, 2003 10:26 PM
