how does compression effect you car getting bar'd
Old Mar 17, 2009 | 06:45 AM
viciousef9's Avatar
Default how does compression effect you car getting bar'd
Ok I am build a jdm b18c bottom end and I want get it resleeved and put some 12:1 compression pistons in. I want to also get the car bar'd as a 97 spec type r. I have all the sensors so that's not the problem. But I keep hearing that if I raise the compression higher then the type r stock form I will have issues. And since I don't want to adjust anything on the stock usdm ecu. I have a problem. So what could I do other then swapping out pistons after the motor has been ref'd? Thanks. Please keep negative comments to yourself.
Old Mar 17, 2009 | 06:52 AM
ACTION JACTION's Avatar
Default Re: how does compression effect you car getting bar'd
If you want to raise the CR higher than stock, you will need to get it re-tuned and there are multiple ways to do that. You could run a socketed p28, so you dont have to touch the stock ecu. If you want to run the stock ecu with stock program then you are limited to light mods like i/h/e.
Old Mar 17, 2009 | 06:59 AM
viciousef9's Avatar
What do you mean by a socketed p28? I have a p28 w/s100 also but I was told that I need the usdm ecu that goes with the motor. What if I ran a thick head gasket? I'm not really sure but that all I can reallt think of doing.
Old Mar 17, 2009 | 12:55 PM
viciousef9's Avatar
does anyone else have any info
G2IntegraGS
Engine Management and Tuning
May 2, 2009 05:51 PM
94lsvtec
Jul 19, 2008 06:56 PM
dwarfsinhondas
Apr 7, 2008 02:44 PM
BrokeAssWhiteboy
Nov 29, 2004 05:33 AM
Mr_CRX
Jul 15, 2004 02:57 PM
