98 spec R swap for sale
1998 Spec R swap with JDM R trans with the 4.7 final drive . Motor has 100k on it makes great compression all the way across the board it made 210 on every cylinder. I just replaced the timing belt, water pump, cam seals, front crankshift seal, oil cooler seal and, PCV system seal also. The trans has no grinds in it i just replaced all of the bearings in it also. The clutch is a ACT stage 1 with a stock flywheel. $2750 Located in Birmingham Al.
VnZo
Aug 23, 2011 09:35 PM
