b18c specs??
Old Mar 16, 2009 | 07:39 PM
b18integraboy's Avatar
Default b18c specs??
ok im looking into buying a new motor for my car. i found a seller on hondamarketplace selling a jdm b18c. now it has a black valve cover so im asuming that its not a jdm type r and just a sir b18c. what is the specs and diffrences of this motor??
Old Mar 17, 2009 | 03:51 AM
96b18c-r's Avatar
Default Re: b18c specs??
Someone could have painted the valve cover easily. but if not..
Now i could be wrong because i don't have an "Sir" but if the code is b16a:
The spec's on the Sir would be - ( had to look it up )
Maximum power 170.3 PS (168.0 bhp) (125.3 kW)
@ 7800 rpm
Specific output105.3 bhp/litre
1.73 bhp/cu in
Maximum torque 157.0 Nm (116 ft·lb) (16 kgm)
@ 7300 rpmbmep 1236.9 kPa (179.4 psi)
Specific torque 98.43 Nm/litre
But i have a b18c type r:
The spec's on the JDM B18c Type R - (200hp, 137ft.lbs tq.)
My opinion, i love my motor. go with the type r if you want reliable,strong, & fairly quick. The sir on the other hand, honestly don't know much about it.. But it aint what other people want, its what you want to be driving.. my preference is quick but reliable and no boost because everything now days is boosted. all motor to me makes a how different feel.. but in the end, boost is where a lot of people wanta be.
Old Mar 17, 2009 | 04:00 AM
delbert's Avatar
b18c
1797
10.6:1
180/7600
Old Mar 17, 2009 | 08:09 AM
itr#1334's Avatar
Originally Posted by delbert
b18c
1797
10.6:1
180/7600
x2
Old Mar 17, 2009 | 08:20 AM
thanks every one
Old Dec 20, 2010 | 09:59 PM
Jdm_King01's Avatar
Here are the Specs for a B18c
98+ Integra Type-R (JDM) B18C
98 Spec-R
* 1797cc
* 4 cyl, 16 valve
* DOHC VTEC
* 10.0:1 c.r.
* PGM-FI (MPFI)
210 bhp @ 8100
Redline: 8900 rpm 18.5Nm @ 7500
Old Dec 20, 2010 | 10:48 PM
racebum's Avatar
98 Spec-R
* 1797cc
* 4 cyl, 16 valve
* DOHC VTEC
* 10.0:1 c.r.
* PGM-FI (MPFI)
210 bhp @ 8100
not correct but probably not your fault. lot of bad information out there. the motor has 200hp, redlines at 8400 with fuel cut at 8700 and has 11:1 compression
Austin Weir
Nov 22, 2018 11:40 PM
swizz977
Jul 28, 2010 10:46 AM
Deo
May 3, 2009 02:02 PM
vrrodri
Jul 16, 2003 07:30 AM
jdm-spec-eg
May 17, 2003 10:00 PM
