jdm 5 lug suspension problem>>need help
whats good guys i need help..i just purchase some front jdm itr 5 lug suspension,with out lower and upper control arms,to make my 95 integra 5 lug...would it still work on my car..?..or would i have to go back to engine depot and get the jdm lower and upper control arms so it could work..?.. i would like to know some info ,before i take my car apart..i notes that the ball joint from the jdm 5 lug is bigger..am a little worry....help..
i just try to install it and the ball joints from the jdm nuckle's are bigger ..it does not work on the usdm lower control arm....i think am have to go back to jdm engine depot to see if they have the jdm upper and lower control arms.....maybe then ,it would bolt right up
My mechanic did it long time ago on my teg over 5 years ago. Just don't remember what was involved but mine came off the white ITR from Schaffer racing in Maryland. I can ask my mechanic for you since he was the one that did it on my teg.
I have jdm 36 mm itr knuckels with lower control arms, gsr knuckels with lower control arms, 96 itr 4 lug& control arms, usdm 32mm itr spindels all sitting off my car, I can look for you if you still need this info. PM me and remind me.
All the parts are interchangable, you will need just a new pair of axles 36mm that you can find them in Ebay for $119 + shipping NEW!!! Recently I did the conversion and all fit in my GSR without any problem. Don't change the hub just buy this axles in ebay almost mine are working very good.
Cool Cool Island Breezes. BOY-EE
It's a bitch to do...but it will be cheap if you can find them at junkyards.
Or do what the other guy said and buy the Ebay axles.
whats good meng...this is my problem so far....the ball joint screw from the jdm 5 lug is bigger then the hole for the 95 integra lower control arm...ye look at the pic...please help me out...what to doe....?...>>>>
this is the stock 95 integra ball joint and the jdm one look how different they are...thats why it does not go in to the lower control arm...........>>>
tysonlifemv
Mar 30, 2009 10:21 AM
kos99ngel
Jul 25, 2005 07:39 PM
