Need Help, B18C High-comp spark plug GAP
Old Mar 16, 2009 | 05:19 PM
B365ir's Avatar
Default Need Help, B18C High-comp spark plug GAP
hey all.... I wanna ask, how much spark plug gap I need???
this is specification of my engine, which is I thing it can support this topic :
Comp 12:1
Accel 300+ ignition n Coil
and last ist Toda B cam,
how much I need for the GAP???
n waht is the best plug I need? Iriduim? NGK or Denso?? or the other?
Because I seggest all of this can be gain my motor Power.. :D
thank u..
Old Mar 17, 2009 | 06:55 AM
B365ir's Avatar
Default Re: Need Help, B18C High-comp spark plug GAP
need help.....
Old Mar 17, 2009 | 07:33 AM
ruffrhyder's Avatar
I use NGK BKR7E copper plugs, the 6097, but they seem to be hard to find now. I was told they are switching to a newer number. But start with a 7 heat range at .044". If you can afford the dyno tuning, gap them at different settings to check for gains.
Old Mar 17, 2009 | 11:39 AM
B365ir's Avatar
thanks ....
Old Mar 21, 2009 | 03:53 AM
B365ir's Avatar
anybody can expalin... what the theory to do this??
now I set it @ .05"??? How about that??? give more gap?? or reduce the gap???
Old Mar 21, 2009 | 05:13 AM
mar778c's Avatar
Community Builder
Community Influencer
reduce the gap. start at 0.032".
Old Mar 21, 2009 | 06:01 AM
B365ir's Avatar
why lower than stock (0.044)???
I've aup my comp.ratio, my cam, n my ignitioN??
I think it's mean I need more gap n my part can do that..
thx,
please tell me why u think like that....???? If I think ur statement is right.. I follow u....
Old Mar 21, 2009 | 08:57 AM
00b20vtecoupe's Avatar
less gap for high cr motors!!! ive always been rec. .038 for my gap. also use the cheap copper plugs by ngk they r like 2 bux a plug.
Old Mar 21, 2009 | 09:17 AM
DC_Legacy's Avatar
I'm running .040 gap on NGK BK7RE-11's with my LS/V which is 12.1:1. I used to run the NGK ZFR5F-11 on my previous LS motor (9.4:1). Since I gained roughly 45-50 extra BHP by going the LS VTEC route I gapped my plugs accorinding NGK's recommendations
http://www.ngksparkplugs.com/tech_su...p.asp?mode=nml
Old Mar 21, 2009 | 07:07 PM
B365ir's Avatar
How about this statement :
Originally Posted by 93-lsvtec-eh2
we dynoed a buddys 12:5to1 2.0 lsvtec with ported head jun3's and smsp header and with back to back dyno runs with no changes we changed the plug gap from .38 to .44 and then .35 and there was a difference of 5 whp opening the gap from .35 to .44. i'm not sure if something else came into play but ect and iat was around the same and so was everything else. he was running ngk 7's
Originally Posted by coneheadsracing
Compression Spark Plug Gap
Up to 10.5:1: 0.050" - 0.060"
10.5:1 - 13.0:1: 0.040" - 0.050"
Above 13.0:1: 0.035" - 0.045"
Straight from msd themselves. It's just a start though. The bkr7es i think they are, its what the boost guys run, i had a set from that, and the gap was good for my 13:1 compression... just an fyi.
http://www.msdignition.com/pdf...s.pdf
page 3
https://honda-tech.com/forums/all-motor-naturally-aspirated-44/how-build-%22reliable%22-lsvtec-b20vtec-1676914/
Old Mar 21, 2009 | 07:32 PM
DC_Legacy's Avatar
Originally Posted by B365ir
What about it?
Old Mar 22, 2009 | 05:50 PM
B365ir's Avatar
I don't really know about that! may be u know that....
any body can help me???
Brandi18c1
Dec 13, 2012 09:21 PM
EM1203
Mar 9, 2009 07:17 AM
thielkedelsol
May 17, 2006 12:57 PM
1FSTNDN
Mar 18, 2006 10:30 PM
