mini-me obd0-obd1 jumper code 41, last code!
Old Mar 16, 2009 | 03:33 PM
johnwohl's Avatar
Default mini-me obd0-obd1 jumper code 41, last code!
This is the last code that I have to figure out for my d16a6/y8 mini me.
I'm running an obd0-obd1 jumper harness to a p28 ecu.
The code I am getting is code 41 for the o2 sensor heater.
I have it wired as follows.
A6-PO2SHTC O2 sensor heating element control
B1-IGP2 02 sensor heating element power
D14-PHO2S O2 sensor signal
B2-LG2 ground
Is this correct?
I made the observation that with the o2 sensor wired this way the idle is high and i think the ecu is in limp mode. I tried connecting both heater wires to batt pos and the idle was lower and no limp mode but still got the code.
The only thing I can think of is that im using a universal bosch sensor, but if that was the wrong sensor it should screw up the signal and not the heater right? Should I try one from the dealer? I'll have to cut the harness so I can't return it if I do.
Any ideas? This is the last code I have.
kuks24
11
Jun 24, 2019 04:59 AM
~sp33~
13
Jan 14, 2009 12:30 AM
importnoodles
Mar 29, 2008 10:20 AM
b_serious
Jan 26, 2006 05:22 AM
