OBD2A car OBD2B engine
OK... what do you have to do.
car: 96 civic
engine: 99 y7
harness: 96 y8
PROBLEMS:::::::::::::
BUNCH of plugs dont go to anything
dizzy wires, theres 2 blue ones on the obd2a, and only 1 blue on the obd2b dizzy
tach and spedo dont work
IAC wont work (of which i have heard of a 2 to 3 swap)
HARDLY RUNS RIGHT. with the iac disconnected it wont idle right. first gear shakes back and forth real bad... (1/8th throttle is the berwah berwah berwah berwah of the iac problem)
QUESTION:::::::::
anyone have DIZZY pinouts (obd2a and obd2b)
anyone have suggestions?
car: 96 civic
engine: 99 y7
harness: 96 y8
QUESTION:::::::::
dont tell me to swap to obd1... or buy a conversion harness...
I HAVE BOTH HARNESSES. I HAVE BOTH ECU'S
with all obd2b stuff connected, theres no spedo/tach
i have a 99 hx, turns out 99 hx's are obd2A not B
i swapped a 00 Si b16 into my car (obd2B)
i had the same problem
switch the harness from the B to the A
the A engine harness should have 4 plugs
3 go to the obd2A ECU and 1 goes to the A car
firejackal
13
Oct 28, 2015 03:02 PM
91daINTEGRAda91
11
May 19, 2009 09:49 PM
