Problem with CRX in Venezuela
TEXT IN ENGLISH:
Hello friends, I request excuses to them by my spelling I do not speak the English very well, my from is Venezuelan, places the text in a translator, I write to them because I have a problem with my car I have a 88 CRX HF, recently buys a friend, the original motor of the CRX is damage and the friend amount d16z6 but he have not the system of injection, intake manifold, Ecu, harness, distribuitor, him amount a carburetor, now I want to put d16z6 again injection but I have several questions on, that…. Engine wiring harness OEM of the CRX serves d16z6 to him? Distribuitor The OEM of the CRX serves d16z6 to him? That Ecu I can mount that is not one p28? Thanks and Greetings!
TEXT IN SPANISH:
Hola amigos, les pido disculpas por mi ortografía no hablo muy bien el ingles, soy de Venezuela, les escribo porque tengo un problema con mi carro tengo un CRX 88 hf, lo compre hace poco a un amigo, el motor original del CRX se daño y el amigo monto un d16z6 pero como no tenia el sistema de inyección, intake manifold, ecu, harness, distribuitor, le monto un carburador, ahora yo quiero poner el d16z6 inyeccion de nuevo pero tengo varias preguntas sobre, eso….
El engine wiring harness OEM del CRX le sirve al d16z6??
The distribuitor OEM del CRX le sirve al d16z6??
Que ecu puedo montar que no sea una p28??
Gracias y Saludos!!
Note: if somebody talks spanish much better jeje
TEXT IN SPANISH:
Gracias y Saludos!!
I'm gonna change your quote to try to make some sense of it.
sorry if i misinterpreted that.
carberated vtec sounds like fun, i would keep it if it was my car. why do you want to change it? for the wiring harness you will have to either modify one or buy one thats modified already. you can check out rywire.com for a wiring harness.
i dont know much about d series but hopefully someone will chime in that does.
TEXT IN ENGLISH:
Hello, excuse my spelling I do not speak English very well, i'm from Venezuelan, , I have a problem with my car I have a 88 CRX HF, recently bought from a friend, the original motor of the CRX was damaged and my friend put a d16z6 in instead, but he didn't have the correct parts for the injection, intake manifold, Ecu, harness, distribuitor, he installed a carburetor, now I want to get the d16z6 running on fuel injection again but I have several questions on, what Engine wiring harness do i need? what Distribuitor? which Ecu can i use that is not one p28? and what exactly will i need to convert back to stock .Thanks and Greetings!
me gusta el color de tu carro. Rywire.com vende los cables que vas a necesitar para poder quitar el carburador y poner fuel injection.
crx_si-r: hermano si tienes MSN damelo para agregarte y asi explicarte mejor!!
grog: thanks for your help bro!!
dorkzracing: gracias hermano! voy a meterme en esa pagina para revisar lo de los cables, si tienes MSN damelo, saludos!!
pdiddyparsons
Nov 12, 2002 05:16 AM
