Valves???
Old Mar 16, 2009 | 01:21 PM
eddiebuiltEK.'s Avatar
Default Valves???
im going to be running an all motor 2.0l gsr and im planing to run toda spec c camshafts and springs now i was wondering which valves to go with supertech or skunk 2?? and also what the differents with the oversized ones and its pro's and con's?? thanks for your help
Old Mar 16, 2009 | 01:43 PM
Combustion Contraption's Avatar
Default Re: Valves???
I personally like SUPERTECH valves. The "differents" with the oversized ones is that they are bigger. Pro = bigger hole, more flow. Con = weight, reduced v2v clearance.
Old Mar 17, 2009 | 03:15 AM
jdm_ef9's Avatar
Supertech
Old Mar 17, 2009 | 12:56 PM
would i benifit much if i only run oversized valves on the intake sized and has anyone ran oversized valves on toda spec c?? and what was the v2v clearance??
Old Mar 17, 2009 | 01:07 PM
Im sure someone has run TODA C's with OS valves, and yes you would benefit from running them only on the INT side. v2v changes with every head, depending on a number of factors, so no one else's v2v numbers will help you any.
Old Mar 17, 2009 | 01:13 PM
yeah because that a big fear for my v2v to be off but would i even need over size ex size for all motor?? and whats the differenet between disha and flat valves??
Old Mar 17, 2009 | 02:52 PM
OK, I have been nice enough this thread, giving out good advice. If you dont know the difference between flat and dished valves, and OS valved motor with TODA C's is not for you.
eTiLiKo
13
Mar 5, 2010 07:49 AM
confusedSol
Oct 29, 2006 01:37 AM
iTR.EX
Dec 6, 2002 12:53 PM
Turbo R
Jul 5, 2002 05:07 AM
