When a Honda TECH says your Fu(ked.......
Old Mar 16, 2009 | 12:59 PM
Fibercation's Avatar
Default When a Honda TECH says your Fu(ked.......
you probly allready knew you were F***d lol
Heres my little slice of heaven ive been dealing with
I removed my rear brakes off my 94 integra sedan to press in new bushings etc and ive done Tons of rear disc swpas/removals but never have broke this bolt. There are two bolts that hold the rear trailing arm bushing to the car...well i broke one and its in the frame of the car. I figured id have to drill it out ...tried to use a easyout from sears and nothing... then figured id have to drill it completly out then re tap. well easiar said than done considering its upside down and recessed so it was't exactly in the middle but as close as possible and now the hole is bigger than the bolt lol
so im down to somehow get under teh rear seats and cut untill i get to the frame and see if i can weld a new nut on or just straight get the trailing arm welded to the car...hey its not a adjustable part of a alignment...heheh i know ghetto but its my last plan of action?!?!?!
anyone else care to brainstorm with me?
Old Mar 16, 2009 | 03:47 PM
commotion's Avatar
Default Re: When a Honda TECH says your Fu(ked.......
pictures?
Old Mar 16, 2009 | 07:57 PM
fasterthanueg's Avatar
i had this problem with a friends car, welded it and traded the car in
Old Mar 17, 2009 | 06:01 AM
trrbl1bmx's Avatar
haha, sounds like your down chit creek with no paddle! If you want to keep the car then you can cut a hole a weld a nut on the back side, if not, weld it and wholesale the car!
Old Mar 17, 2009 | 09:01 AM
hondakevin21's Avatar
It seems this is pretty common lol. Weld in a new nut and call it a day that or maybe helicoil, i'd feel safer with a new nut and bolt though. Good luck, keep us posted.
Old Mar 17, 2009 | 02:57 PM
srmofo's Avatar
drill the hole bigger and tap it. it doesnt matter what thread pitch as long as it works. and if it isnt centered just drill it a little bigger until its close enough. and use a hand wrech to install that bolt, not an air tool
Old Mar 17, 2009 | 03:58 PM
x3772's Avatar
New User
shane you could just drill the top end of the bolt hole out and put a full locknut and bolt set on it.
Old Mar 17, 2009 | 04:33 PM
well as far as just welding a nut on um....the oem way is the nut is ressed inside the frame rail...i hop if i can cut some of the metal above it (under the rear seats) i can get to it ....i dunno any other way
Charlie Moua
15
Sep 5, 2014 01:51 PM
gunnis
12
May 24, 2006 08:40 PM
Type V
Suspension & Brakes
14
May 8, 2006 04:57 PM
MeanGreenEG9
Sep 18, 2002 04:24 PM
CivicEK.PDX
Sep 12, 2002 06:42 PM
