lsvtec head gasket? what else works?
Old Mar 16, 2009 | 11:38 AM
DrGrEeNtHuMb's Avatar
Default lsvtec head gasket? what else works?
So my first lsv I sprung for the golden eagle lsv kit. It came witht he sandwich plate and oil line and headgasket and the little plug for the oil squirter. Well this time I don't wanna spend that much and want to see what head gasket I can use? The setup will be a b20z with a first gen b16 head.
Old Mar 16, 2009 | 11:40 AM
mar778c's Avatar
Community Builder
Community Influencer
Default Re: lsvtec head gasket? what else works?
Just order another head gasket from GE.
Old Mar 16, 2009 | 11:43 AM
ruffrhyder's Avatar
Or cometic
Old Mar 16, 2009 | 11:44 AM
deadazleep's Avatar
As stated in https://honda-tech.com/forums/all-motor-naturally-aspirated-44/how-build-%22reliable%22-lsvtec-b20vtec-1676914/ you can use the b20z head gasket. Just have to modify it a little
Old Mar 16, 2009 | 12:11 PM
1. What is the cosmetic head gasket?
2. What would ihave to modify on the head gasket?
Old Mar 16, 2009 | 12:18 PM
numberone's Avatar
Originally Posted by deadazleep
As stated in https://honda-tech.com/forums/showthread.php?t=1676914 you can use the b20z head gasket. Just have to modify it a little
Why would he have to modify it?
Old Mar 16, 2009 | 12:25 PM
DC_Legacy's Avatar
Cometic, not cosmetic. And for roughly $70 (what i paid) you wont need to modifiey anything plus they make this gasket for the Frankenstein as a means of improving the LS/B20 gasket design for cooling and rivit placement.
Old Mar 16, 2009 | 02:16 PM
numberone's Avatar
Nice. Nuff said!
Old Mar 16, 2009 | 03:58 PM
Ok thanks guys! Hopefully this build will be better than my last lsv. This time I have a b16 head ported to match the type r with all type r valcetrain and the b20z bottom end. Way nicer compared to my worn out 180k ls and stock gsr head I used to have in the dc
new_climber
Honda Civic (2001 - 2005)
Aug 28, 2023 12:11 PM
Davidkak
Apr 3, 2010 12:13 AM
da_33
Jan 11, 2007 11:12 AM
mulin
Nov 3, 2004 09:25 PM
