suspension question
Old Mar 16, 2009 | 10:40 AM
Armorzaku's Avatar
Default suspension question
ok well im checking out craigslist and this guy is selling neuspeed springs that came off his 98 gsr and i was wondering if they will fit on my 95 LS SE?
need an answer soon because this guy is holding em for me!
Old Mar 16, 2009 | 10:51 AM
mrdeadman's Avatar
They let me pick
Default Re: suspension question
yes.
How much are they?
And why do you want them?
Old Mar 16, 2009 | 10:56 AM
Armorzaku's Avatar
75 and to lower my car
Old Mar 16, 2009 | 11:00 AM
mrdeadman's Avatar
They let me pick
You will probably need new struts after yours blow. And the car will probably ride like ****. In two weeks you will be the one selling the springs and somebody else will be asking if these springs will fit his car.
Old Mar 16, 2009 | 11:02 AM
Armorzaku's Avatar
my ride with the stock stuff is smooth.
these will blow them out?
and it will ride choppy?
Old Mar 16, 2009 | 11:07 AM
mrdeadman's Avatar
They let me pick
If the springs are not matched to the dampers, the dampers will blow over time.
Lowering springs tend to make a car ride like ****.
Old Mar 16, 2009 | 11:08 AM
Armorzaku's Avatar
well how long do i have?
and which springs are the best to get with stock struts and stuff?
Old Mar 16, 2009 | 11:12 AM
mrdeadman's Avatar
They let me pick
What do you want to do with the car?
I would suggest a coilover system.
I stay away from lowering springs, maybe someone else can help you there.
Old Mar 16, 2009 | 11:14 AM
Armorzaku's Avatar
well im going to drop it, type r lip, and an exhaust.
thats just the outside.
under the hood you know, h/e/i, intake mani, cams, the little stuff.
Old Mar 16, 2009 | 11:16 AM
mrdeadman's Avatar
They let me pick
Lowering springs is not the route I would go.
Old Mar 16, 2009 | 11:28 AM
Armorzaku's Avatar
well i only got 250 right now, so im trying to fix up my car with it.
dont know what i should do with it
Old Mar 16, 2009 | 11:31 AM
mrdeadman's Avatar
They let me pick
Don't spend it on lowering springs. Save your money.
Is your car already running alright? If not I would use the money to fix it.
Old Mar 16, 2009 | 11:32 AM
Armorzaku's Avatar
yeah its running prime, the only thing bad is the paint, so i want to make it look good you know first before i start working under the hood
Old Mar 16, 2009 | 12:07 PM
racebum's Avatar
the rates and amount of drop will dictate if they work with your stock struts. if they are less than a 2" drop and not the race spring rates they will work with your stock shocks.
Old Mar 16, 2009 | 12:16 PM
imroadk1ll's Avatar
if i were you since your car is running pretty well i would just keep saving for coilovers. dont make a mistake like a lot of people do they buy springs then blow the struts and then they end up buying a whole new coilover system.
Old Mar 16, 2009 | 12:36 PM
Targa250R's Avatar
be professional
Nobody can tell you that for certain. It depends on a lot of factors.
Only something very mild, like Tein S.Tech springs. The stock shocks really shouldn't be used with anything other than the stock springs.
Old Mar 16, 2009 | 01:21 PM
berb_15's Avatar
It's painful but the best way to go is just buy shocks built for lowering springs/coilovers too when you do it, that way you won't be taking your suspension off down the road to replace your struts after they go
Old Mar 16, 2009 | 07:19 PM
jerBEAR's Avatar
I made this mistake a long time ago. I put skunk2 coilover sleeves on my stock struts and the blew the same month. My car rode like *** for a couple months until I could afford to purchase new KYB AGX shocks to compensate for shorter springs. Even at that, I was not pleased with how my car rode, so I saved even more money to purchase a full coilover system. Save your money.
PeachesAndHerb
Suspension & Brakes
10
Jun 23, 2012 11:52 PM
emegge
Suspension & Brakes
Feb 26, 2007 07:47 PM
biglos
Honda Civic (2006 - 2015)
Nov 29, 2006 01:51 PM
pregunta
Apr 5, 2003 11:27 PM
TQ
Apr 22, 2002 12:39 AM
