Difference between type R shifters??
Old Mar 16, 2009 | 10:23 AM
Shimakid12's Avatar
Default Difference between type R shifters??
I was thinking about purchasing a type R shift lever instead of going with something else like skunk2 or something. When I look up the shifter lever it seems that there are two different ones. In 97-98 it gives me the parts code: 54101-ST7-000, and in 2000-2001 it gives me the parts code: 54101-ST7-Z00. The 97-98 spec shifter is a bit more expensive also. I was wondering if there are any differences between the two, and if so, what are they? Is one of a better qualitly/feel? Also, are they both dual bend? Any light shed on the subject would be greatly appreciated. Thanks.
Old Mar 16, 2009 | 10:27 AM
REDTMNT's Avatar
Default Re: Difference between type R shifters??
97-98 you get the leather wrapped **** with red stitching, 00-01 is the aluminum **** with the red numbers. Both are great IMO just depends on what you like.
Old Mar 16, 2009 | 11:12 AM
Shimakid12's Avatar
Oh I was talking about the actual shift lever, not the ****. Sorry, guess I wasn't specific (edited). Thanks for the info though. Still wondering what the difference is in the lever itself between the years.
Old Mar 16, 2009 | 11:20 AM
BlueIntegraBoy's Avatar
Shifters themselves were the same (dimensions) except one was normal black and the other was polished.
Old Mar 16, 2009 | 11:32 AM
Shimakid12's Avatar
do you know which one was polished and which one was black? Are they made out of the same materials? Thanks.
Old Mar 16, 2009 | 11:34 AM
Both are steel. 97-98 were black and 00-01 were polished.
97-98 middle, 00-01 right
Old Mar 16, 2009 | 01:08 PM
Shimakid12's Avatar
Thanks thats exactly what I needed to know. Appreciate it.
Old Mar 16, 2009 | 02:30 PM
1tuffbb6's Avatar
Old Mar 16, 2009 | 03:28 PM
Racebrewer's Avatar
But, the one on the far left will shift with less movement.
Whatever it is.... Check out the Heel&Toe shifter for real performance.....
John
Old Mar 16, 2009 | 09:27 PM
bluebomber's Avatar
Information Leafblower
I think BlueIntegraBoy knows everything there is to know about Integras. I swear you're in every thread
Old Mar 17, 2009 | 01:01 AM
Correct, the left one is an MFactory short shifter
Old Mar 17, 2009 | 08:44 AM
CW-ITR's Avatar
Just in case you didn't know, his bedroom is the back seat of his R and the front seats are the livingroom. LOL
Old Apr 1, 2009 | 03:52 PM
Wfbeast70's Avatar
not trying to thread jack, but does this come with everything pictured above or do you have to order the inner pieces as well? i put an arrow next to the part that i am talking about.
Old Apr 1, 2009 | 07:34 PM
You need to order the sleeve and o-rings
Old Apr 2, 2009 | 10:27 AM
imnotjdm's Avatar
how does that mfactory one perform?. does the shift feel alot shorter...?
Old Apr 2, 2009 | 11:17 AM
Slightly shorter. It is like a Skunk2 shifter.
xracer6
Dec 18, 2015 07:58 AM
4gen5thtime
May 12, 2009 10:14 AM
Shimakid12
Sep 2, 2007 07:03 PM
danteisme
Feb 22, 2004 02:58 PM
KitKat
Jul 3, 2003 03:45 PM
