manual timing belt tensioner?
Old Mar 16, 2009 | 10:00 AM
eg_h22's Avatar
From: Beautiful beaches, skies, and ladies. No worries(.) @ the OBX, NC
Default manual timing belt tensioner?
How should I go about tightening the belt with my manual tensioner? When I installed it I just simply pushed up on the tensioner before I tightened it and that just didn't make it tight enough. It kinda flaps when the motor is running and I think my cams are a tad bit off bc of it
Old Mar 16, 2009 | 12:58 PM
toomspeed's Avatar
Default Re: manual timing belt tensioner?
Ok, i have the same one. you need to take a 10mm bolt , front the cover will work, and put it in the hole that lines up in the arm. make sure the slack is on the right side. Now I used a pry bar to push down on the arm and snug up the bolt. i needed a extra set of hands for that.
annette'shonda
Apr 8, 2013 12:39 PM
danewickenhauser
Jul 25, 2009 04:38 PM
drbenne
Nov 19, 2007 01:39 AM
skrewdlude
Oct 4, 2005 04:42 AM
SpoolinEK
Dec 17, 2003 05:39 PM
