gsr rebuild 220whp
motor:
-usdm itr nippon pistons and rings
-stock gsr rods and crank
-oem rod and crank bearings
-oem b16 oil pump
-ctr n1 crank pully
-apr rod bolts
head:
-mild port and polish with a three angle valve job
-super tech valve train
-bc stage 2 cams
-sk2 cam gears
-sk2 pro intake manifold
-blox 70mm tb
-hondata intake manifold gasket
-bisi header
-spoon 2 layer head gasket
-rc 310 injectors
-custom cold air intake
-arp head studs
fuel:
-255 walbro
-91 oct
tranny:
-2 gen b16
-obx lsd
-act stage 2 clutch kit
-stock flywheel
ecu:
-p28 rechipped
dont know much about the rechipped p28 but i was told its as good as any hondata program. the ecu has an outlet for a laptop but will need a piggy back or somthing like that. like i said im not familiar with this rechipped program but hopefully it will get the job done. i plan on having my car tuned at low cash racing in phoenix az. hopping to push 215-220 whp with some good tuning. so what do you guys think is this possible with my setup
-oem b16 oil pump
-ctr n1 crank pully
-apr rod bolts
head:
-bc stage 2 cams
-sk2 cam gears
-blox 70mm tb
-bisi header
-rc 310 injectors
-arp head studs
fuel:
-255 walbro
-91 oct
tranny:
-2 gen b16
-obx lsd
-stock flywheel
ecu:
-p28 rechipped
if i were you i'd go with some forged internals if you wanna reach the 220 whp mark i built a gsr with forged 12.5:1 compression pistons, eagle rods, and a built head it made 226 whp
