Any one know how to roll up a power window manually?
So I can't roll my passenger side window up. It's power windows. I'm pretty sure there's a way to roll up the windows manually but not sure how...(mayb using the two wires from the motor and connecting it with a battery?) If anyones done this or heard of hollaz...
Damn man, if you really need to, gotta take out the door card, take out the motor and lift it using the regulator. Not fun and time consuming.
If the window is not working, it's likely the relay. You can remove the relay and use a jumper wire to allow the window motor to receive power and roll up. Much easier than disassembling the door. Unless of course the motor is junk or everything is all jammed up. You didn't clarify though.
the motor ain't junk. I'm having wiring issues and just need to close the windows for now until I find the source of the problem. Gonna try jumping the motor.
civicpraning2k1
Honda Civic (2001 - 2005)
Jul 29, 2010 08:45 PM
si_motor_spt
14
Jul 12, 2010 01:37 PM
