b18a1 into a ef shell need help
Old Mar 15, 2009 | 04:55 PM
waterfordtuners's Avatar
Icon2 b18a1 into a ef shell need help
i have the motor complete wiring ecu tranny for the b18 what else do i need to put it into my ef shell i no i need motormounts axels but what else am i gona need
Old Mar 15, 2009 | 05:01 PM
just-ef-it's Avatar
Default Re: b18a1 into a ef shell need help
shortened da integra shift linkages, or hasport b swap linkages
Old Mar 15, 2009 | 05:06 PM
D16SiHatch's Avatar
Things you'll need/need to do:
-ls engine and trans
-da intermediate shaft
-da axles
-obd1 or obd0 pr4, up to you. if obd1, you will need ecu jumper and 4-wire o2.
-convert fom DPFI to MPFI if car is not already equipped, i.e. (Si, or Hf model) You cannot use the teg engine harness)
-eBay,avid,hasport,innovative, etc shift linkage, or shortened teg linkage
-b-series into ef mounts from eBay, avid, hasport, innovative, etc.
-90-93 teg throttle cable
-90-93 teg rear transmission bracket, must be from a 5spd
-pull out the dust rings from inside your hubs. this allows more room for the axle to move and prevents the constant velocity joints from binding on lowered vehicles.
-lastly, you will need to make a dent on the lower driverside frame rail to allow for alternator pully clearance.
Old Mar 16, 2009 | 06:26 AM
thanks alot man
BigT21
Jun 20, 2009 02:21 PM
crvb20z
Apr 6, 2009 05:09 PM
88 EF Hatch
Feb 27, 2009 12:50 PM
Dane_GSR
Sep 7, 2008 08:00 PM
D3U1LT
Jan 24, 2006 08:30 PM
