FS- B16, GSR, D16Y7, EK EF parts galore! CHEAP! Raliegh-Durham NC!
Old Mar 15, 2009 | 02:57 PM
Boostfed86's Avatar
Default FS- B16, GSR, D16Y7, EK EF parts galore! CHEAP! Raliegh-Durham NC!
Contact- David
919-697-5922
PM/Text/Call
Location- Durham, NC
So... Started cleanin up the Garage tonite and ran across a bunch of stuff I don't need anymore. Prices are not Firm but, they're cheap enough I really don't want to budge a lot of the Prices. Pick up everything Listed for $350!!!!
P72 GSR Cams w/ cam gears- 75$. Just removed from a head I purchased- No pics yet.
Valvesprings and retainers to match cams above
- 25$- will remove them this week at work.
B-series flywheel- needs a resurface- 30$
D-series flywheel- needs resurface- 25$
OBD0 B16 Dizzy-
Pulled this from a customer car converting to OBD1. He decided to Keep the OEM look and we repinned to the OBD0 Harness plug. It was in great working shape when removed, only pulled to go to OBD1. Throw a new plug on it off a junk dizzy and you'll be great! $75 OBO
Damaged GSR head-
I used this head as my mock up for my setup. I purchased it from NCVTEC1313 a few months back. I'm nearly done building my motor now, so mock up is nearly complete. The head is damaged pretty badly on Cylinder 1. I've seen worse be repaired but its all up to you. Still has the rocker shafts and everything attatched to the rocker shafts. Nothing else is still in the head, its completely bare otherwise. $50 and its yours or I'll sell it for scrap aluminum and get the same thing.
D16Y7 Alternator- Pulled off a motor pulled from a customer car. This came from the motor i put in the car. Pulley is dented but you can swap it out or just try and straiten it. I'm not sure exactly if it works but, i bought the motor from a wrecked car. I assume it works great and I'll garuntee it. $40 and its all you.
D16Y7 Dizzy- Pulled from same customer car as above. Same condition as alternator, Can't verify that it works but, I'll garuntee it. Take it home for 40$.
Precision T3 Turbo Housing- Don't know what turbine wheel this is for but, its a .63 A/R T3. Its for quite a large Wheel, My GT30R didn't come close to fitting. I assume its probably near a PTrim wheel. 30$ and its all you.
Prothane motor mount inserts for EK- SOLD!
B16A2 intake manifold- Completely bare- IAT sensor included but nothing else. $20 and make it your own!
EF sunVisor- OEM honda equipment. No cracks or chips. In MINT shape. These are getting hard to find and their value is starting to skyrocket. I've seen them sell for over 100$ on ebay and honda-tech. $75 and you can bolt it to your own car!
Brand new Walbro 255
. Bought this before i switched to my Full-Race sump and aeromotive setup. No longer have a need for this. Its brand new, just pulled it out of the box. I can Install it and ship it to you on the original fuel tank mounting setup for 100$. I'll take 75 shipped for the pump.
Trades considered-
Skunk2 Pro1 all motor cams
ITR/CTR Cams
68mm+ throttle body
Aeromotive A1000 fuel pump
DOHC VTEC valve cover
5 Bar Map sensor
GSR LSD
13X8 lenso's/Bogarts
24.5X8in slicks
universal Intercooler piping(2.5in or bigger)
Boost, oil pres, water temp gauges
Old Mar 15, 2009 | 09:16 PM
Boostfed86's Avatar
Default Re: FS- B16, GSR, D16Y7, EK EF parts galore! CHEAP! Raliegh-Durham NC!
up up!
Old Mar 16, 2009 | 02:01 AM
pinks11's Avatar
good prices, wouldnt mind picking up the walbro pump tho
Old Mar 16, 2009 | 02:46 PM
Boostfed86's Avatar
Walbro is still availible! Mount inserts sold locally!
Old Mar 16, 2009 | 08:46 PM
Boostfed86's Avatar
offers are more than welcome!
Old Mar 17, 2009 | 03:45 PM
Boostfed86's Avatar
up up!
Old Mar 17, 2009 | 04:57 PM
WeakSi's Avatar
David do you have a B-Series stock clutch?
jdmjackal
Jan 17, 2013 09:41 AM
darkDB1
Jul 8, 2011 05:09 PM
mRek9R
Sep 17, 2010 10:58 PM
Civmochris
Aug 21, 2003 08:47 PM
