Help please! 36mm 5-lug
Old Mar 15, 2009 | 01:45 PM
tico_ek9's Avatar
Default Help please! 36mm 5-lug
I have a ITR 36mm 5-lug swap ready to be installed..But I have a 99 civic hatch with the 32mm d16y7 still in it. is thier any way to do this? Does it have to be a B-series motor?
Or any links where I can buy 32mm/36mm axels? or can I swap out the hubs? please help out stuck on this.....
Old Mar 15, 2009 | 02:47 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Help please! 36mm 5-lug
trade the front spindles for USDM itr stuff. i dont know if you pop off the outters and swap them is possible.
Old Mar 15, 2009 | 07:07 PM
tico_ek9's Avatar
itr is bigger
Old Mar 15, 2009 | 07:18 PM
White civic's Avatar
you must had a 98-2001 itr 36mm 96-97 32mm
Old Mar 15, 2009 | 07:23 PM
tysonlifemv's Avatar
i just pmd you....please help me out...if you can......
Old Mar 15, 2009 | 07:27 PM
i need help on some info....i got jdm 5 lug suspension and i would like to know what kind of problems am going to run into wen i install it,into my 95 integra.....please some one help me with some info...is everything the same..?
Old Mar 15, 2009 | 07:29 PM
Icon2 Re: Help please! 36mm 5-lug
is their enyone that could help me with some info..?
Old Mar 16, 2009 | 03:16 AM
Mr. Badwrench
Originally Posted by tico_ek9
itr is bigger
usdm itr is not. usdm itr is same as what you have. (axle wise)
Old Mar 16, 2009 | 03:18 AM
Mr. Badwrench
if it came with axles you are fine. everything fits.
i put a 2001 jdm itr 5 lug on my civic it came with axles so i was fine, i was also engine swapped at the time.
Old Mar 16, 2009 | 03:27 PM
6Spd_EJ6's Avatar
i have 32mm spindles ill trade you..
mpls
Aug 27, 2013 04:54 AM
hondacivichatch
Sep 25, 2005 12:33 PM
SIR Spooner
Mar 26, 2004 10:04 PM
highrpmek
May 28, 2003 03:07 PM
