Fully Built LS-Vtec Motor/ Full race Kit
I have a fully built setup, built by mynes proformance in meza, AR. Setup was built and broken in properly, theres about 1k on the setup. everything is in great condition and ready to drop in and go. Selling because i need to take advantage of this market and get myself a house, or to buy a Evo.
TURBO KIT AND ECU SOLD!
Tranny Sold- Legomytego
HeadStuds SOLD- Acura98guy
1 set of corners
Side Markers
z10 Girdle- Ej8chu
Comp Clutch SOLD
Complete LS-Vtec longblock(Ready to Drop in)
$3500 FIRM
-84mm RS Sleeved Block
-84mm Oem headgasket
-GE ls-vtec kit
-Aries 9:5:1
-Eagle H-beams
-Arp head bolts
-Arp Mains
-Acl bearings
-ITR Water/Oil Pump
-Rotating assembly Balanced
-Moroso 5qt baffled pan
OBD1 B16 Head:
-Ported and Polished By S&S
-Fearra Valve Springs
-Fearra Ti- Retainers
-ITR Cams
-Skunk2 Pro gears
-ITR intake manifold
-ITR throttle body
-AEM fuel Rail
-AEM Reg
NEW LISTINGS
JDM 94-00 Integra clock cover BNIB $10
- B series vtec harness $100
- MSD coil, cap, wire, BNIB $50
- 2001 GSR manifold $75
- OBX bseries manifold $50
-92-95 civic corners $10
-Greddy SP catback for 92-00 coupe or 94-00 integra $250
- Eagle H-Beam B16 rods BNIB $250
- 2 gsr half shafts $ 50 each
Napa Stage 2 Axles $250
If you want it all make an offer.
Cash Only or Certified Bank Check
1 set of corners
Side Markers
z10 Girdle- Ej8chu
Comp Clutch SOLD
$3500 FIRM
-GE ls-vtec kit
-Aries 9:5:1
-Eagle H-beams
-Arp head bolts
-Arp Mains
-Acl bearings
-ITR Water/Oil Pump
OBD1 B16 Head:
-ITR Cams
-Skunk2 Pro gears
-ITR throttle body
-AEM fuel Rail
-AEM Reg
NEW LISTINGS
If all you need it a gate then buy one. if you cant afford a tial or "Anything good" then buy a cheap nock off
longblock still forsale, also have a CM clutch, MSD coil,cap. Jdm side markers, jdm integra clock cover, bseries vtec engine harness and some other parts i will be listing here when i am not lazy.
