EG Shift Linkage into an ej8
Old Mar 15, 2009 | 09:51 AM
tfeagley's Avatar
Default EG Shift Linkage into an ej8
Found out my issue was the shift linkage. They failed to mention the shift linkage came out of an EG. I heard there was a way to cut and weld the EG shift linkage to make it work. Its on a b16a
I have a shift linkage out of a 97 d16y8..would that work?
Old Mar 15, 2009 | 10:00 AM
the jdmchop's Avatar
Default Re: EG Shift Linkage into an ej8
92-00 civic sohc shiftlinkage are the same
92-00 dohc shift linkage are the same
delsol is the only special one!
if you have a b-series motor then u need the b series shiftlinkage!
Old Mar 15, 2009 | 10:26 AM
tfeagley's Avatar
The only thing is the motor was in an EG before and it had no problems so shouldnt it work fine in my ej8? It mounted up perfect and i can get 3rd and 4th gear i just cant get 1st or 2nd.
Old Mar 15, 2009 | 10:56 AM
sure you installed it right?
can you move the shifter left to right?
Old Mar 15, 2009 | 10:59 AM
tfeagley's Avatar
sure can. Just seems like it wont go into 1st or second. Shifted fine in the EG
Old Mar 15, 2009 | 11:02 AM
can you do it when the car is off, put it in 1 or 2?
clutch works fine? bad slave or master can cause it not to go into gear.
Old Mar 15, 2009 | 11:10 AM
tfeagley's Avatar
See thats the thing. Its damn near impossible to tell which gear is which. I believe i have it in first cause it feels the same way it did when it was in the EG. First gear had alot of play and almost felt like neutral.
Old Mar 15, 2009 | 11:18 AM
did you remove the shifter from the linkage when you pulled the swap?
Ricextacy
Mar 31, 2010 09:04 PM
flipldls
Transmission & Drivetrain
Oct 22, 2009 12:33 PM
the.hamburglar
May 22, 2008 05:56 PM
jin4g63
Sep 7, 2007 01:29 PM
Anti-Drama Queens
Sep 18, 2006 04:51 PM
