my car wont atrart HELP!!!!!!!!
i need help my car aint starting.. i got a 91 honda civic dx i just put in a jdm zc swap on it.. da car cranks but dont start..i check if theres spark goin on da spark plugs dats fine.. i check da fuses its all good i dont kno wat it is anybody got any ideas.. thanks
Every time you say 'da car...." this or that, i think of my DA, like integra. It's hard to help when i'm decoding your dialect. But i think you said it's all good under your hood as far as ignition spark. So, next i would see if your fuel pump is coming on, if your injectors are firing, or just pull a spark plug and see if it smells like fuel. Fuel, compression, spark: all you need. Also, make sure the spark you see is bright blue, and like bam_89 said, check your other ignition parts like wires, cap, and rotor.
hey, and just wondering; why zc? i mean there are b18 a, b, and c at the junk yards here, couple that with some mounts and your getting more power for less than your zc was to ship. so, was it some jdm kick or doing something different?
Hey bud, people are more inclined to helping you if they don't have to sift through gibberish to find out what your problem is. Try using proper english, it'll get you a lot farther round here. I'd start first with the big 3, spark, fuel, and timing. If your spark is good, make sure you have fuel. If that is good, make sure your ignition timing and cam timing is correct.
kidguitar87
Aug 8, 2010 02:51 PM
