GSR oil/water pump on b18a1?
yes its possible... people do it for ls/vtecs.. the gsr pump has 22teeth as opposed to the ls' 17teeth...point blank, you'll pump better at higher rpms
its your decision, you have all the info you should need
pro: they will flow coolant and oil faster.
con: they arent free and you will have to do some work.
as far as the water pump i have no idea.
