Is this ok if I camber it???
Well I have an CRX DX and I have the camber set for 13x5 rims. But i'm thinking about putting on 14x6 rims on to it. Would that be ok if I camber it????
whats the offset of the 14x6 rim and what size tires are you using?
if the offset is +38 and up w/ the normal sized 185/60-14 then yes, keep the camber setting the same. if you have any weird wear and/or if your car is pulling then check it out.
Yeah the offset is +38 and I am goin to get 185/60-14 tires.... So what you think that it would be ok and this to put the wheel on like what with the same camber??? Because i'm not running an fast engine, and I would use the car for work so I know go 55 the fastest.
Yeah my camber is set for correction, and my car is 5 and a half inches form the ground. I am still running the stock rims but I think the 14x6 the with would be close... But idk that's why i'm asking you =P.
joelmatt89
Oct 7, 2009 01:55 PM
Sterndotstern
Nov 25, 2004 05:57 PM
