Is my head gasket on wrong? Pic inside
Old Mar 15, 2009 | 12:08 AM
averyvm's Avatar
Default Is my head gasket on wrong? Pic inside
Hey whats going on HT, man oh man have i been having problems with this car. Anyways heres the deal. People have been telling me my headgasket is on wrong. I thought it could only go on one way. but maybe just maybe I manage to do some crazy ish. anyways heres a pic let me know what you guys think. YOu got to look a lil close.
Old Mar 15, 2009 | 12:25 AM
ej8green's Avatar
Default Re: Is my head gasket on wrong? Pic inside
if you aint got no water in your oil and your car doesnt smoke then you should be fine because technically if you take your head off and check to see if your oil and water holes are lined up then you have to get another head gasket because there only ment to be torqued down once. so i would weigh the factors. but if youve been running it for a while and have no problems then i would leave it alone IMO.
Old Mar 15, 2009 | 12:44 AM
teamworxek9's Avatar
what kind of problems are you having?
Old Mar 15, 2009 | 07:45 AM
jdong's Avatar
Yap it is. that suppose to be on the other side. below the vtec solenoid.
Old Mar 15, 2009 | 08:21 AM
94civiccupew/b7's Avatar
it can only go one way. the 2 top corner head bolt holes are offset. so if you had it backwards, all the head bolt holes of the gasket would not match up with the top of the block
Old Mar 15, 2009 | 08:24 AM
did u torque it in the correct sequence and to the correct ft/lbs?
Old Mar 15, 2009 | 11:19 AM
jdong's Avatar
This is ls engine right? Is still ok but off a little bit. just torque it the right way.
Old Mar 15, 2009 | 11:24 AM
dohcdelsol's Avatar
oem gasket? the sohc gaskets say "up" on them. id assume the dohcs do also
redacura
Feb 17, 2019 05:34 PM
averyvm
Mar 25, 2013 05:00 PM
central_driver
21
Oct 21, 2008 11:24 AM
UTCiv
Apr 2, 2004 04:16 PM
CRXGSR
Aug 18, 2003 08:51 PM
