how do I remove hub from spindle assembly?
Old Mar 14, 2009 | 03:34 PM
Nichelson_Performance's Avatar
Default how do I remove hub from spindle assembly?
can anyone tell me how to get the hub out of the spindle assembly so I can install my new ARP extended wheel studs?
car is a 2000 Civic EX coupe also is it the same process to do the rear hubs too
spindles are already out of car
Old Mar 14, 2009 | 03:40 PM
B16B_coupe's Avatar
HRD PKR
Default Re: how do I remove hub from spindle assembly?
You need to take them to a shop, you have to press them off and back on. most of the time you end up having to replace the wheel bearings.
Old Mar 14, 2009 | 03:52 PM
that blows but its worth it for arp studs especially when i have a new set of buddy club lug nuts to go with it
Old Mar 14, 2009 | 03:55 PM
B16B_coupe's Avatar
HRD PKR
I would be very carefull with buddy club lug nuts, heard a few people say they come loose on them while driving."HARD" driving
B16B_coupe's Avatar
HRD PKR
Do you have rear drums?
Old Mar 14, 2009 | 04:00 PM
yea unfortunately, disc brake conversion is next years project
i'm hopin the lug nuts will stay tight, i always hand tighten them since you never know when you will have a flat tire. anyhow the only hard driving i ever really do is at the track or when i do a 1st or 2nd gear pull
Old Mar 14, 2009 | 04:02 PM
B16B_coupe's Avatar
HRD PKR
I see, i wouldnt install the rear extended studs till you get rear disc, the only safe way is to put a tac weld on each stud from the rear after you install them.
Old Mar 14, 2009 | 04:14 PM
which buddy club lugs you talking about? i have the P1 magnesium/aluminum alloy ones
Old Mar 14, 2009 | 05:28 PM
KillBot's Avatar
Here is the FAQ...with bad pics:
https://honda-tech.com/forums/showth...ght=wheel+stud
Old Mar 14, 2009 | 06:06 PM
B16B_coupe's Avatar
HRD PKR
No i wouldn't install the studs on rear drums if your upgrading to rear disc, you will have to buy new rears then
Old Mar 14, 2009 | 08:22 PM
EK2.0's Avatar
Sometimes you might have to get new bearings, sometimes not. usually the shop will warn you before they press your stock studs out and press in the ARP's.
I just took my whole spindle to the shop and they were able to press the studs out n in without having to disassemble the hub from the rest of the spindle, so that was nice.
Old Mar 16, 2009 | 11:57 AM
well i got the fronts done without any trouble, took them to work today and used our 25 ton press and pushed them right out without hurting the bearing...it was actually a good idea taking them out because the bearings were pretty dry so they got a good grease job while i had the hub out
now i just have to do the rears
peppers75
Honda CR-V & Element
15
Jun 25, 2011 09:31 AM
88 EF Hatch
Oct 15, 2009 09:33 PM
ALLMOTOR CRX
Mar 14, 2007 10:08 PM
VRD^don
Oct 14, 2002 04:53 AM
dynamo
Sep 20, 2002 11:37 AM
