Car wont Start?
Old Mar 14, 2009 | 02:26 PM
Dave_Dc2's Avatar
Default Car wont Start?
Just built my 12.1:1 gsr motor. car cranks over and has spark but wont fire. stock obd2 ecu with stock injectors. walbro fuel pump and aem fuel pressure regualtor set at 42 lbs. i checked all the grounds and fuses. and 2 different distributors...anyone?
Old Mar 14, 2009 | 02:34 PM
00Red_SiR's Avatar
All Motor Mentor
Default Re: Car wont Start?
check all the basics. Make sure all your fuel injectors are plugged in, your ignition timing is where it should be, your cam timing is where it should be and your plug wires are in the correct firing order. Try dropping in a new set of plugs that aren't gas washed.
Old Mar 14, 2009 | 06:06 PM
J240sx's Avatar
I would say cam and crank timing. It will crank over but won't start sounds like that may be your issue.
Old Mar 14, 2009 | 06:16 PM
Dave_Dc2's Avatar
ill go ahead and do that..any other ideas than the basics?
Old Mar 15, 2009 | 09:21 PM
mouab18c1's Avatar
Well you should eliminate the basics before doing anything else
Gary Harlan
Nov 19, 2016 04:15 PM
dc2doi
Jan 6, 2008 01:43 PM
94thundergrey
Apr 18, 2004 04:39 PM
