High speed vibration
Old Aug 12, 2002 | 03:52 PM
whtdc2's Avatar
New User
Default High speed vibration
HI there, my car¡¦s steeling wheel vibrate a lot when I brake at high speed- 185km +, I just have a new rotor fitted. What wrong with it? I have Tein RE suspension and the Skunk2 camber kit fitted. The man who look after my car said the vibration is coming from the camber kit, what do you guy think? Thanks in advance
Old Aug 12, 2002 | 10:21 PM
kkim's Avatar
Default Re: High speed vibration (whtdc2)
was the vibration there before the rotor install? was the camber kit installed prior to the rotor or at the same time? if the camber kit was already in there before the rotor, sounds to me like the surface of the hub was not cleaned before the rotor was installed and it is not sitting flush on the hub.
Old Aug 12, 2002 | 10:38 PM
whtdc2's Avatar
New User
Default Re: High speed vibration (kkim)
Thanks Kkim, the problem is I can't recall I have the camber kit or the rotor first.
Old Aug 13, 2002 | 04:18 AM
vtec.dc2's Avatar
when you changed brake rotors, did you change the brake pads too? if not, they might have uneven surface and cause shaking.
Old Aug 13, 2002 | 04:27 AM
01PYITR's Avatar
new rotors are not allway true, get them cut ever so slightly.
lovelove
Jun 22, 2009 06:07 PM
Shongku
Nov 7, 2007 10:06 AM
h22addiction
Aug 8, 2006 09:04 PM
Fooman
May 16, 2002 12:04 PM
tC_Dragon
May 13, 2002 02:59 PM
