did my iacv but..
Old Mar 14, 2009 | 03:20 AM
imroadk1ll's Avatar
Default did my iacv but..
ok so i did this today and when i first started my car it had a really hard time starting about 3 seconds to finally start up. then it idled around 2k then gradually went up to 3k?? is t his normal and now wen i put it to neutral to stand by my car rattles and drops kinda close to like around 5 close to the 0 rpm so when i put it to first it kinda rattles again. idk i think i just messed it all up.
Old Mar 14, 2009 | 06:51 AM
5litereater's Avatar
Default Re: did my iacv but..
A slight air bubble in your cooling system could drastically affect your idle. I'd try bleeding (or rebleeding) your system.
Old Mar 14, 2009 | 07:21 AM
JasonsGS-Ah's Avatar
New User
GL man
Old Mar 14, 2009 | 02:56 PM
Steven.'s Avatar
Did you clean your iacv you mean?
Did you tighten the bolts back all the way along with the gaskets that may of fallen off of it?
Try starting your car when cold with the radiator cap off and squeeze out any air bubbles
Old Mar 14, 2009 | 03:48 PM
iluvmyda's Avatar
if its irratic idel most likely the tps sensor/
Old Mar 14, 2009 | 05:49 PM
imroadk1ll's Avatar
ok so this morning i plugged one of the hoses that i took off, i seriously thought i put it back on but now its all good. i think i didnt see the an o ring so ill try and check again tomorrow to see if its not there ill buy one from honda
Da_1991
Apr 8, 2014 09:01 PM
jonyi27
Apr 22, 2013 05:32 AM
elliascool
Apr 30, 2011 06:34 AM
black0hatch
Jan 22, 2008 08:55 PM
byronl
Jun 14, 2006 08:26 PM
