Has anyone tried Lotus Exige wheels?
Old Mar 13, 2009 | 10:51 PM
bsmith100's Avatar
Icon2 Has anyone tried Lotus Exige wheels?
Has anyone tried Lotus Exige wheels(either oem or aftermarket)? These wheels are 4x100 with offsets between 27mm and 32mm.
So if I run 10mm or 15mm spacers on an EK, then they should fit. Does that seem right?
Old Mar 13, 2009 | 11:09 PM
r.wright's Avatar
Default Re: Has anyone tried Lotus Exige wheels?
if the wheel is already 27mm offset and you added a 10mm spacer it will bring the wheels OUT 10mm meaning the offset will be like a 17mm offset wheel.
i found this :
http://www.sandsmuseum.com/cars/elis...up/wheels.html
looks like the center bore will work but then the stagger might be kinda weird unless you found 4 fronts. offset is okay already..not too crazy
Old Mar 13, 2009 | 11:39 PM
bsmith100's Avatar
i found this :
Oops, I guess I had that offset thing all wrong.
Old Mar 13, 2009 | 11:41 PM
bsmith100's Avatar
I had actually been thinking about running 4 fronts.
Old Mar 17, 2009 | 03:30 AM
blinx9900's Avatar
wow, that could look decent...
andrewmoquin
Jul 20, 2009 01:52 PM
lsegcoupe
Apr 2, 2007 09:16 PM
JoeyBallzSI
Oct 20, 2003 03:04 PM
sk898
Dec 18, 2002 02:22 PM
