how do i tell what tranny is what?
will i know this is a knoob question but i was getting ready to buy a lsd tranny and the guy say is a itr transmission but i see the sticker on the tranny read the code s80 #######? is s80 a gsr tranny ?thanks in advance of all the help provide thanks
look through the hole inside the trans where the axel goes...if you can see all the way through its LSD, if you cant, its not. does that help?
thats a true fact?for sure im goin to go check it out before i buy it his askin for like 1200 and is still in his car i dont want to waste allot of money if its not lsd
more info i found....which probably makes it more confusing.....
S80 -- found in Integra Type R 98+ (LSD), JDM SiR-G (optional LSD), JDM 96-97 Integra R (LSD), JDM Civic R [EK9] (LSD), JDM Civic SiR [EK4, EG6] (optional LSD).
weighing the odds, i would say yes it would be LSD.
s80 were all shared by the gsr/itr and ls. the way to tell if it's LSD is to look at the hole where the half shaft goes through. if u can see through it then it's lsd, if u see a little bar in there it isnt lsd.
the only difference in the tranny is the final drive ratio.
in this case yes im sort of wrong, in other cases, i would be right
ok guys thanks very much im goin to check it out tomorrow if i see threw the tranny where axle goes its lsd if you cant see threw it aint lsd
hatchbackhonda
Jul 27, 2004 03:24 PM
And i believe only difference from a s4c to a s80 is 4th and 5th are different .
