cel em1
so i had the code "1 long blink = 10" i changed my o2 sensor primary on header the cel is back on i used the universal sensor cut the harness off oem and connected it frustrating any help
check your IAT its on top of the intake mani double check to make sure its plugged in. im not 100% sure if you can take it out and clean it but if it is plugged in try and see if you can clean it
There is A black I believe 2pin maybe 3 I can't remember connector connected on the top of your intake manifold. You CANT miss it. It has a nipple for a vacuum hose on one side.. Make sure it's plugged in. I know the wires a green n red.. If it's plugged in then take it off and clean it.. Are your runnin a chipped ecu by any chance?
Yeah, first make sure the IAT connector is plugged in. Second, clear the code from the ECU by removing the under-hood 7.5A BACKUP fuse for 1 minute and then reinserting it. Drive the car and note whether or not the CEL turns ON. If not, you are good to go.
i will do that after i pick up a valve cover today
If you have a em1 as stated: Part number for IAT- 37880-P2A-004
Quick test
2. there 0.4–4.0 k ? If NO then replace the sensor
If yes which i highly doubt there will be, let me know and ill help you from there
Here is a picture on a real em1 if you needed to know what it looks like
Its number 23 in the picture If you need to order it from your dealer
Quick test
1.Measure resistance between the terminals on the IAT sensor.
dont_tri
Jul 27, 2007 10:17 AM
