battery relocation problems
Old Mar 13, 2009 | 01:15 PM
ef-hatchcrap's Avatar
Default battery relocation problems
ok so I bought 0 gauge wire for the setup. I ran a + to a distrubution block to the front with an in-line breaker. when ever I give the distrabution block power by hooking up tthe battery it blows the main fuse on the shock tower.
I have 1 ground going to where the dounut usually bolts too and the other going to where the rear strut bolts to the chassis.
If I don t connect the wire that goes from the block to the fuse panel on the shock tower it doesnt blow the fuse.
I have it wired like my brothers car witch I did and he has no problems any help is great thanks
Old Mar 13, 2009 | 04:03 PM
Ldo's Avatar
Ldo
Default Re: battery relocation problems
How big is your main ground wire?
Did you check to make sure the distribution block itself is not touching any metal? Sounds like there's a short somewhere.
Old Mar 13, 2009 | 07:07 PM
shaggyeg6si's Avatar
Make sure your ground is as large as your power wire. Also, try to get a better ground than that, making a new ground somewhere that there is nothing is a good idea. Also, make sure to ground away the paint.
Red EK 92
May 9, 2013 12:18 PM
95vteccoupe
Apr 2, 2010 08:12 AM
watacivic
Audio / Security / Video
May 19, 2007 12:37 PM
EFz6er
Aug 4, 2005 10:29 AM
crdcz03
Jun 22, 2005 07:08 PM
