Bolt broke connecting trailing arm to lower control
Old Mar 13, 2009 | 11:53 AM
corkss's Avatar
Default Bolt broke connecting trailing arm to lower control
I'm in the process of changing my spring, shock set up. Thebushing going through the bolt groing through the control arm and the shock was junk so I decided to take the whole control arm out, when the bolt connecting the control arm to the trailing arm , the head broke off, I have no idea what to do next...other than get a whole to trailing arm and control arm?
What are my options here?
Thanks in advance?
Old Mar 13, 2009 | 01:14 PM
honda.lioness's Avatar
Default Re: Bolt broke connecting trailing arm to lower control
Air die grinder. See http://honda.lioness.googlepages.com...sionrenovation . Since you are in snowy Wisconsin, expect more frozen bolts and so consider the impact wrench, and technique for it, discussed at the latter web site as well.
Old Mar 13, 2009 | 01:41 PM
Bthasht's Avatar
A torch is the best way. Heat all bolts up B4 attempting to remove them. As for the broke one cut it out to allow the LCA to drop, but leave enough room to get vise grips on the part that treads into the trailing arm. Heat it up and twist it out.
Old Mar 13, 2009 | 01:49 PM
hanszl2001's Avatar
New User
I had the same problem last wednesday during a diy trailing arm bushing swap. I had to went to a garage to fix it.
So I saw what they did with a small air grinder: grind off the welded nut of the schock and replace it with a stainless steel bolt and nut.
Old Mar 13, 2009 | 02:09 PM
robfrmny21's Avatar
cut the back side that is threaded on the trailing arm, then use a long bolt with a a locking washer and nut to replace what you cut off
Old Mar 13, 2009 | 02:22 PM
fastrxu's Avatar
those only have a couple inches of thread then you tap them a little bit with a hammer right? try threading it as if your tightening it with some vice grips and then you can tap it out correct me if im wrong
Old Mar 13, 2009 | 02:38 PM
corkss's Avatar
well, thankfully its the only problem bolt, i got all the other corners done..
My aircompressor is havin issues lately, any other ideas to cut that welded nut off without a die grinder....I guess if I have to I will do it manually with a saw..haha
i have a sawzal.... angle grinder perhaps?
Old Mar 13, 2009 | 03:59 PM
94EG8's Avatar
Seagull Management
Hacksaw believe it or not. I've tried a sawzall on those bolts, their too hard and the saw is too fast, it just burns the blade. You'll have to cut it off between the bushing and the inside of the trailing arm, remove the old bushing in the LCA and replace it, either remove the last bit of bolt from the trailing arm or cut off the captive nut and replace it with a regular nut and a new bolt.
Old Mar 13, 2009 | 04:03 PM
lcsej1's Avatar
usually before i try to take anybolt outside the car i spray some PB and let it sit overnight. Somebolts are just a pain and you will need a torch!
Old Mar 13, 2009 | 05:02 PM
corkss's Avatar
sounds good guys, i'm gonna use the ol hacksaw at it tomorrow...
thanks
Old Mar 19, 2009 | 07:00 PM
pantherninja's Avatar
haha...I am currently doing the same thing. Again...i am glad to see that others have done it successfully many times.
daniel-em1
Suspension & Brakes
Jun 13, 2011 02:41 AM
MaXiMuS1701
Jun 29, 2007 10:12 PM
ActiveAero
May 14, 2006 10:22 AM
kyden
Suspension & Brakes
Jan 25, 2006 10:56 PM
