FS/FT: Fully built AWD 600hp talon
Old Mar 13, 2009 | 10:56 AM
Go n 4 10s's Avatar
Default FS/FT: Fully built AWD 600hp talon
1991 AWD Eagle Talon, 120,000 miles....
Economy sux, need to sell out right or trade for another car i can drive. I have about $26,000 dollars in recipts in hand for this car so dont bother tryin to low ball me. 90% of this car is brand new and has never been ran yet. It has a clean FL tittle in my name ready to go. Car needs a tune and its good to go. Everything is here, not missing anything, just lost interest. I want $10,000 for it as it sits, Like I said everything is almost new, car is super clean, no rust/dents only a little fender fade. Any more info please call (386)852-4473
***UPDATE***UPDATE***UPDATE***UPDATE***UPDATE
NEW PICS ARE UP!!!! Will take $8,000 OBO or trade for a running driving car of equal valuse....This is the cheapest you can buy a 10 second race car anywhere, guaranteed!!!!!!!
Motor:
Stock 4g63 6 bolt block, approx 40,000 Miles on block
NEW OEM crank, shot peened
NEW Crower Oversized rods, coated
NEW Ross Racing piston 8:5.1
NEW Teflon bearings
NEW Total seal Moly rings
NEW Gasket match ported head from Mitsubishi
NEW Webb Stage 3 cams, not re-grinds .415/.390 lift
NEW Crower Ti Valves
NEW Crower Ti Springs/retainers
NEW Greddy Timing belt
NEW Crower Cam gears
NEW OEM Oil pump/water pump
Slowboy racing balance shaft removal kit
ARP Head studs, Main studs
Every bolt on entire engine is ARP
Mitusbishi "R" model head gasket, coated
70mm BBK TB
Magnus intake manifold
Fluidyne radiator
NEW Poly mounts through out
Motor was fully machined, built and balanced by PCC, Twister racing engines in Kissemme. they balanced everything from the Crank pulley to the Flywheel
Have receipts and motor has NEVER BEEN STARTED!!!!
Drivetrain:
New OEM PTO Transfer case
40,000 AWD tranny
New Driveshafts/Axles
92 4 bolt LSD rear
New ACT 4 puck non sprung disc
NEW ACT maxx extreme Pressure plate
NEW ACT prolite flywheel
Power Slot rotors
Hawk racing pads
Steel Braided lines on WHOLE CAR, Brakes,Clutch
Turbo:
NEW Precision SCM61 turbo, same as GT35r minus BB (HPC coated)
NEW Hahn racecraft 3" DP (HPC coated)
HKS 44mm Wastgate
NEW Greddy Type RS BOV
ATR 3" full Exh
NEW HPC coated and ported EVO 3 Exh manifold
2 1/2 mandrel Bent charger pipes
BIG *** Front mount 30" by 14" by 3"
Blitz boost controller,turbo timer
ECU/Ignition:
NEW Halltech E6s stand alone ECU with datalogging, Stutter box, etc etc
NEWCrane DIS ignition box
MSD 9mm wires
MSD Coils
Fuel:
Aeromotive A 1000 Pump with filter
Aeromotive rising rate FPR
FIC Fuel rail
FIC 750cc injectors
10 gallon Aluminum fuel cell flush mounted in trunk
-8 feed lines
-6 return
Gauges:
ALL NEW!!!
Autometer Phantom:
Oil pr.
boost
Water temp
Fuel Pr.
AFR
Greddy EGT gauge
VDO 5" tach
Interior:
MINT 10 out of 10!!!!
RARE special edition checkered flag OEM interior option
10 Pt painted, certified, DOM moly cage good to 9.50's
MOMO steering wheel
MOMO pedals
Optima Red top in trunk
No radio
DEI alarm
Exterior:
8 out of 10, need fresh coat of paint thats it
Custom made fiberglass hood, not sold anywhere in US
Rolled rear fenders
All factory and simple
the coupler thats missing in these pictures^^^ is on order right now
Old Mar 14, 2009 | 01:02 PM
Go n 4 10s's Avatar
Default Re: FS/FT: Fully built AWD 600hp talon
Ttt
Old Mar 14, 2009 | 01:35 PM
hondachris1994's Avatar
Bro Y dont u goahead and assemble the motor to the body and get that thing running before u trade/sell because its gonna b hard to sell/trade it that way especially when the new owner is gonna have to have all that towed not to mention assembled and tuned.
Old Mar 14, 2009 | 01:40 PM
16yroldekownr's Avatar
+1^^
Old Mar 29, 2009 | 09:19 AM
Go n 4 10s's Avatar
BUMP......motor and everything is installed, just needs a tune
Old Apr 10, 2009 | 06:55 AM
Go n 4 10s's Avatar
bump
Old Apr 12, 2009 | 07:43 PM
Go n 4 10s's Avatar
I farted
Old Apr 12, 2009 | 08:30 PM
Folgers's Avatar
checked this cutie out the other day, its a badical car.
Old Apr 16, 2009 | 02:40 PM
Go n 4 10s's Avatar
TTT still for sale
Old Apr 18, 2009 | 05:24 AM
Go n 4 10s's Avatar
Ttt
Old Apr 18, 2009 | 07:14 PM
Go n 4 10s's Avatar
up up and away
Old Apr 19, 2009 | 01:17 AM
DohctorVtec's Avatar
Are you ever going to keep a car? :\
Old Apr 19, 2009 | 07:45 AM
Go n 4 10s's Avatar
Are you ever gonna finish a car?
Old Apr 19, 2009 | 09:08 AM
Finishing cars is overrated. Just seems like whenever you get a sweet project you dump it like in no time after you get it.
Old Apr 19, 2009 | 11:38 AM
Go n 4 10s's Avatar
Yah, having no job, a mortage, bills, a 8 month old chilid and no form of income will do that to you
Old Apr 19, 2009 | 12:25 PM
Go n 4 10s's Avatar
bump new pics
Old Apr 20, 2009 | 03:56 PM
Go n 4 10s's Avatar
Monday
Old Apr 20, 2009 | 04:47 PM
JDrummel's Avatar
Monday Night..
bodybuilding88
Aug 5, 2011 08:57 AM
slick32112
Jan 21, 2010 10:16 AM
Go n 4 10s
Apr 20, 2009 03:55 PM
hatch34
Northwest (Sales)
16
Oct 13, 2006 04:31 PM
