Help w/ my Turn Signals!!!!
Old Mar 13, 2009 | 05:54 AM
401RIguy's Avatar
Default Help w/ my Turn Signals!!!!
i Hvae a 95 CX Hatch:
Problem is that:
they dont signal for some reason but then my Hazard lights flash when i hit the emergency button tho!
well, im not sure what to check or look for! not sure if it got a fuse or what but then if anyone can help me out please do so
Old Mar 13, 2009 | 06:11 AM
courtney42's Avatar
Default Re: Help w/ my Turn Signals!!!!
If only the signals dont blink it is a fuse. If the hazards dont work either then it is the relay.
Old Mar 13, 2009 | 06:18 AM
401RIguy's Avatar
yea jus the signals wont work..but then Hazards come on if i push the button tho! and where is the fuse cause i dont have that one cover piece to tell me what is what
thnxs
Old Mar 13, 2009 | 06:32 AM
Former User's Avatar
Check whether fuse 15 under the dash is blown. However, if this fuse is blown, the cluster and back up lights and clock also should not work.
Old Mar 13, 2009 | 06:42 AM
Fuse 15 is fine. The problem is most likely a bad combination switch:
Old Mar 13, 2009 | 07:15 AM
401RIguy's Avatar
cant be the fuse cause the Cluster works just fine and it lights up! just that when i signal it wont come on! so i have no idea what it is! cause CLock and cluster work and light up just fine
Old Mar 13, 2009 | 07:25 AM
It's likely a bad turn signal switch. Check it as shown in the diagram.
S33
Dec 27, 2014 10:22 AM
barone
Jun 4, 2011 07:21 AM
Mishima
Jun 30, 2009 09:08 PM
d16z6hondacrx
Oct 17, 2005 04:36 PM
