Do starters for 94+ integras work in all integras?
I want to swap starters and see if thats the problem but rather then buying one i have 2 other integras that i can try the starter from but i need to know if they work. My car is a 99 gsr and the other 2 are 94. One is a ls and the other is not a gsr but has a gsr motor, i think its obd1. Part numbers for a 94 ls and 99 gsr suggest the parts are different but that could just be a number right? Diagrams look identical. Referenced the part numbers through hondapartsunlimited.com
should work... as long as its a c model engine.. im not sure on the b1s and the a1s though...
94-01 seem to be good at part swapping minus a few parts
Flywheels are the same, and you can interchange transmissions..
It's not like you have plugs going to the starter, so just try either one.
thanks guys i just tried with the gsr starter and it was identical and plugged up. Except it didnt fix my non start problem. Thanks again!
long story here https://honda-tech.com/forums/acura-integra-6/99-gsr-wont-start-help-me-diagnose-2513155/
short story is my car wont start and im troubleshooting one step at a time but ive got most things covered. Narrowing it down except it seems im narrowing it down to 'i have no clue' cuz the common things i thought were it dont seem to be the problem. On to electrical now.
