Wiring OBD2 alternator into OBD1 wiring harness.
Old Mar 12, 2009 | 07:51 PM
311hp's Avatar
Default Wiring OBD2 alternator into OBD1 wiring harness.
Has anyone done this and could provide wiring diagrams for it?
Thanks
Old Mar 12, 2009 | 08:26 PM
itotech's Avatar
Default Re: Wiring OBD2 alternator into OBD1 wiring harness.
I did a 00 Gsr swap on my 94 teg and all the wires are the same color what changes is the plug.So cut your old plug,cut the new plug,match colors and bam..Unless you dont have the obd2 plug from the harness then I cant help you
Old Mar 13, 2009 | 09:36 AM
DC206R's Avatar
i'm going to do a 99 Ls swap int my 95 also, my friend said just swap the alternators instead of cutting any wires.
Old Mar 13, 2009 | 06:04 PM
311hp's Avatar
I have the plug, however there is 2 white 1 blue and 1 black on the obd1 harness side and 3 white 1 black on the obd2 plug I have. Should I just line them up as in (: example: upper left from clip lower right etc etc...) or guess on one of the white ones??
Old Mar 14, 2009 | 12:40 PM
311hp's Avatar
Ok so I looked in the hanes and it states that my integra is supposed to have a black and yellow, white and green, white and red, white and blue, and white however as I stated my wiring harness has different colors than what the book said,, so if anyone can tell me if they have maybe an older integra with blue, black and yellow, white and green and white and blue I'd appreciate it!!! Thanks
Old Mar 14, 2009 | 07:33 PM
311hp's Avatar
anyone?
Old Apr 29, 2009 | 08:04 PM
cfwthb_94's Avatar
I hope someone can answer you because I'm having the same problem
Old May 19, 2009 | 09:22 PM
Nicky's Avatar
Anyone have an answer?
Alex Preece
Oct 3, 2018 07:36 PM
spoon93
Jun 28, 2008 01:49 PM
Dead CIVIC
15
Jan 28, 2008 05:53 PM
lsvtechatch92
Mar 7, 2007 06:44 PM
