Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Anyone running 235 or 245 series tire on EG/EJ1?
Old Mar 12, 2009 | 06:32 PM
turdflo's Avatar
Default Anyone running 235 or 245 series tire on EG/EJ1?
I've seen DC5's running 245's and even an EK hatch running a 255 in the front...
Just wondering what type of wheel offset will allow this? Is it even possible on a 92-95 civic coupe/hatch? Or only on DC5's and EK's?
The wide length of the wheel is a given requirement, but what are the offset requirements? I'd imagine it would have to be less than +30 or so?....
I assume that because I know someone who tried running even a 225 with a 15x6.5 (+35 offset) wheel, and apparently the tire was rubbing with the suspension. (This was on a 93 civic coupe....NOT hatch)
Please discuss how to at least fit a 235, if not 245.
Old Mar 12, 2009 | 06:49 PM
Stinkycheezmonky's Avatar
Suspetise...
Default Re: Anyone running 235 or 245 series tire on EG/EJ1?
With a +35 offset, if the tire was rubbing on something, they were doing something wrong. I'm running 15x8 +36 with 225/45s and have no issue. The WHEEL was contacting the rear upper control arm at one point, but a little work with the grinding wheel took care of that.
As for 245/255, I don't think it would work without seriously flaring the fenders and/or getting very creative with modifying stuff like the trailing arm. 235 might be able to squeeze in there with an "ok" flare and the right offset. However, you'll also be running a bigger wheel, because I don't think there are any 235/245/255 15" tires.
Old Mar 12, 2009 | 06:59 PM
Justin Jones's Avatar
for a 235 you can the toyo r888 235/50/15 but that's pretty tall for an EG/EK/DC
235/40/17 RA1s are apparently a really effective size for a track tire on some EGs/EKs i guess the height is worth the trade off for those guys. Password:jdm race car is one example of an EK running that size.
there's also the avon cr500 245/40/15, supposedly a kickass tire but too soft for even a 2000 pound civic, it'll wear out extremely fast apparently, it's designed for a 1200 pound caterham running a 15x9 rim.
turdflo's Avatar
You are right about the 15" wheel fitment...I should have mentioned it will be 16"...or even 17" since 235's and 245's are easily available for that wheel.
And this would only be for the front...rear is ok with 225 max I'd say
Old Mar 12, 2009 | 07:59 PM
Suspetise...
I should've said 15" tires in those widths that are worth the trouble And yeah, a 235/50 would be pretty tall. The 225/50 V710 has a noticeable effect on gearing, going taller than that would suck, and would limit your ride height.
turdflo, if you really want to do it, I think 17s would be the way to go. 16s have limited size availability, just better than 15s in those widths.
To be a little more helpful, I would think that something right around +30-32 would work. Higher offset than that and you'll probably be rubbing on the spring/shock.
Old Mar 12, 2009 | 09:40 PM
.:Made in OC:.'s Avatar
Contact Benny, (realride) he's running 235's on his H2 civic. He ran into some rubbing issues though.
Charles
Old Mar 12, 2009 | 09:58 PM
EdoMoto's Avatar
Benny is on 225 45 15's.
Edo
Charles
Old Mar 12, 2009 | 10:24 PM
Edo
He didn't want to run the 235's anymore because he rubbed right?
Old Mar 13, 2009 | 02:41 AM
Johnny Mac's Avatar
Interestingly, the new 225-50-14 Toyo R888's are about 1/4" wider than the "same" sized RA1's. If the other sizes of R888's are similarly wide and the fact that the R888's want less camber, the wheel offset will have to be in the 40 range to fit properly.
Old Mar 13, 2009 | 05:14 AM
DAMotorsports's Avatar
i stuffed a 235/40/17 under my EM1
Old Mar 13, 2009 | 05:45 AM
Suspetise...
DA, what offset wheels? And did you need spacers/fender modification/etc, or did it just fit fine?
Old Mar 13, 2009 | 03:56 PM
turdflo's Avatar
+1...some more details, DA!?
Old Mar 13, 2009 | 05:48 PM
realride's Avatar
the 235/50/15 did not fit, I switch to 225/45/15
benny
Old Mar 13, 2009 | 05:51 PM
JW racing's Avatar
Its all in the wheel offset how you can get 235/17 to fit.Along with a hammer.
Old Mar 15, 2009 | 10:13 AM
the wheels started at 45 off set but i also use a 5mm spacer. the finders have no lip and i run neg camber.
Old Mar 15, 2009 | 11:15 AM
Muckman's Avatar
Moderator in Chief
DAmotorsports - do you have any rubbing issues? what about at full lock? Do you run the same in the rear too? what tire and wheel combo? how much neg camber front/rear? I think everyone in this thread would like to see pics and more details about your setup.
Old Mar 15, 2009 | 02:37 PM
turdflo's Avatar
Originally Posted by muckman
damotorsports - do you have any rubbing issues? What about at full lock? Do you run the same in the rear too? What tire and wheel combo? How much neg camber front/rear? I think everyone in this thread would like to see pics and more details about your setup.
+1....
Old Mar 15, 2009 | 06:07 PM
the rims are Rota slipstreams, with Toyo R888. i have no rubbing at this time ( i never use full lock ill have to look), as far as the rear i had to adjust the rear part of the inner finder on the back side. the camber is set to race trim and i have not try street trim. i belive im at 2 degs at this time. ill take some pic in a few day and ill put them up i have the car down at this time, because I'm prepping for a 3 hour race next month
Old Mar 16, 2009 | 09:00 AM
mrlegoman's Avatar
On my EG I run 255/40-17's with +45 offset Motegi's with a 5mm spacer and custom fender work.
Prior to fender work, I was able to run 235's without spacers and just a little bit of custom baseball bat rolling done to the fenders.
Old Mar 16, 2009 | 10:35 AM
turdflo's Avatar
255's...this is nuts. How much camber?
Post pics PLEASE!
Old Mar 16, 2009 | 12:17 PM
mrlegoman's Avatar
Post pics PLEASE!
Stock 1.5 deg in the front and 2.5 in the rear. (Will be increasing front this year up to 2-2.5 degs)
Pics page:
http://www.smallmountain.us/images/car/tires/conti/
Others:
Old Mar 25, 2009 | 03:44 PM
technolud's Avatar
awesome
Old Mar 25, 2009 | 05:32 PM
98SpecR's Avatar
mrlegoman, did you have to modify you RTAs to fit those 255s? Also, I'm assuming you are running 17x9s. Correct??
Old Mar 26, 2009 | 04:13 AM
mrlegoman's Avatar
Currently running a set of Motegi Traklite 2's at a 17x8 +45 offset. No current modification to the RTA's, but I am running 5mm spacers. I do have some modification to the inside of the fender well for added clearance. There is a slight rub on the RTA after track events, but not during d/d. Even though it is a slight rub with no significant tire wear, I am still going to address it with some type of RTA modification this year.
Continental does recommend a 9" wide rim for their 255 ContiSportContact 3's. But was told on the side that they would not be concerned if I ran them on my 8" rim.
Old Mar 26, 2009 | 09:26 AM
turdflo's Avatar
Not sure, so just to check;
RTA = rear trailing arm?
