Stupid valve adjustment question
Old Mar 12, 2009 | 06:25 PM
ludekid4323's Avatar
Icon2 Stupid valve adjustment question
Ok so I just installed a pair of Brian Crower stage II cams along with BC dual springs and steel retainers on my h22. This is my first time doing a valve adjustment so I have a question. Am I inserting the feeler gauge underneath the vtec lobe on the cam for every cylinder? Im doing the adjustment tomorrow but I need to make sure that I do it correctly because it needs to be on the dyno on Saturday...
Old Mar 12, 2009 | 06:34 PM
zsudz922's Avatar
Default Re: Stupid valve adjustment question
here you go man - https://honda-tech.com/forums/honda-prelude-4/diy-h22a-valve-adjustment-618786/
its in the FAQ sticky.
Old Mar 12, 2009 | 06:52 PM
thanks but I allready read that one along with a bunch of other ones. With the pics being dow I cant tell where the feeler gauge is positioned...
Old Mar 12, 2009 | 09:37 PM
MikeLuder's Avatar
Hey man, You're putting the Guage in between the cam lobe, for each valve/screw. Inserting the Guage from Outside to In, (manifolds Inside to the Head) And go on the tight side for Intake and Loose side for Exhuast.
.006 intake (brian crower may have different specs, check)
.008 exhuast
At least that's the best stock valve combination I've came up with, after several trials of different ways.
That DIY in the FAQ is pretty dead on.
91EF919
13
Aug 28, 2009 05:25 PM
Akwhite18
Apr 6, 2009 10:31 AM
bertsb18hatch
Feb 11, 2009 12:03 PM
GReddyTurboCoupe
Jul 17, 2005 03:15 PM
216.226.142.95:27016
Jul 14, 2003 08:03 PM
