b16 wont start
Old Mar 12, 2009 | 06:07 PM
ERKK's Avatar
Default b16 wont start
i got a 90 crx si that i just put a B16 into was out of a 99 civic si.everything is in. I have a chiped p28 that is chipped for a b16 basmap. and i got a dizzy addapter from rywire so i didnt have to buy an obd1 dizzy. My car have a obd0 to obd1 jumper harness in it already. OK it will crank over it sounds so healthy like it wants to put it wont fire. im geting spark. but im really not geting that much fuel i am but like hardly at all. i didnt try a compresion test yet. any help on what you think could be rong would be great
Old Mar 12, 2009 | 06:42 PM
ERKK's Avatar
Default Re: b16 wont start
buhelp asap
Old Mar 12, 2009 | 07:58 PM
crxcess's Avatar
lots of things to check. timing for one. and are you sure everything is plugged in? plug wires in the right order?
Old Mar 12, 2009 | 10:00 PM
ERKK's Avatar
1342 is the firin order and i dont know how to check timin in a b series
Old Mar 12, 2009 | 10:28 PM
ERKK's Avatar
bump
Old Mar 12, 2009 | 10:59 PM
ERKK's Avatar
bump befor bed
Old Mar 13, 2009 | 09:03 AM
ERKK's Avatar
come on
Old Mar 13, 2009 | 11:04 AM
ERKK's Avatar
wow thanks
Old Mar 13, 2009 | 11:08 AM
shaggyeg6si's Avatar
Check timing. Is there fuel in the tank?
Old Mar 13, 2009 | 11:14 AM
ERKK's Avatar
yes there is fuel
Old Mar 13, 2009 | 11:19 AM
Is the fuel pump good? Also, main relay. How's that cam timing?
Old Mar 13, 2009 | 11:22 AM
ERKK's Avatar
fuel pump is good main relay kicks on going to check timing here soon
Old Mar 13, 2009 | 11:25 AM
If you say spark is good, and fuel is good, the only things left are cam timing, and spark timing.
Old Mar 13, 2009 | 11:36 AM
ERKK's Avatar
it gets good spark and i think it may be timin i duno i will be checking today and what you mean spark timin you mean the fireing order
Old Mar 13, 2009 | 11:38 AM
Yes, and also that the distributor is timed correctly. It'll run with it slightly off, but not as well as it should. I got the wires backwards once, so make sure your spark wires are correct.
Old Mar 14, 2009 | 06:53 AM
ERKK's Avatar
Ok timin good i dont think im geting fuel.
Old Mar 14, 2009 | 10:44 AM
ERKK's Avatar
Bump
Old Mar 14, 2009 | 11:24 PM
ERKK's Avatar
help me out here plz
Old Mar 15, 2009 | 07:32 PM
ERKK's Avatar
BUMP i got fuel but it wont come out of my injectors i check like 5 dif sets and not fuel will come out i trun the car and no fuel..
Old Mar 15, 2009 | 08:29 PM
ERKK's Avatar
wow so no one can help me
Old Mar 15, 2009 | 10:20 PM
Shermanef9's Avatar
you gotta be patient sometimes man, EF owners are a dying breed.
Anyways, when you turn the key to on (not start) do you hear the fuel pump?
Old Mar 16, 2009 | 08:06 AM
ERKK's Avatar
yes we alreadys went over my fuel pump kicks in
Old Mar 16, 2009 | 08:23 AM
SweetDA9_TR's Avatar
well man... um check fuel filter..and fuels not coming out of the injectors umm.. check wiring all that stuff but be patient like Sherm said... we are a dying breed...it took me about a year and a half to get mine comp. running correctly and its still has some hickups..like my #4 INJ!!!! UGH!!!!
Old Mar 16, 2009 | 08:34 AM
ERKK's Avatar
put a new new fuel filter in im going to try main relay today see if that helps
Old Mar 16, 2009 | 11:18 AM
ERKK's Avatar
bumpp
