brake pedal idle
Old Mar 12, 2009 | 05:05 PM
thebleek's Avatar
Default brake pedal idle
ok so i have a bad idle. it idles when warmed up from 1500 to 2600 rpms up down up down..etc. I replaced the IM, TB gaskets, and pcv valve. also the hoses.
still had the problem,
so last night i bought some 3/8 hose from autozone [fuel/emissions] and swapped my old brake booster hose for that. I tried blowing into the hose and no air could get thru, I turned it around and blew harder [lol] and i hear a pop and air could go thru. I decided **** it, ill swap the 3/8 autozone hose on... i removed the hose and heard psssst and then switched to the new autozone hose
Now at stops my pedal slightly moves up and down when my idle goes up and down.
wtf?
Old Mar 12, 2009 | 06:04 PM
thebleek's Avatar
Default Re: brake pedal idle
bump
Old Mar 12, 2009 | 06:25 PM
Jbur074's Avatar
my idle does that too... bump for wanting to know the cure!
there is a hole in the bottom left of the TB and if you cover it up it idles normal.. idk wtf it is.. but it works lol
Old Mar 12, 2009 | 07:22 PM
thebleek's Avatar
on the left of the throttle body? thats the map sensor
Old Mar 12, 2009 | 07:27 PM
newtron63h's Avatar
yeah the brake pedal moves up and down with the idle because of the changing manifold vacuum. sounds like the vacuum line to you map is screwed.
Old Mar 12, 2009 | 08:18 PM
thebleek's Avatar
i dont have any vac lines to the map on a d16y7 obd2a do i?
Old Mar 12, 2009 | 08:28 PM
newtron63h's Avatar
oh i have no idea. BUT he says it idles fine when he covers it up. sounds like it should have a vacuum cap or a line going somewhere.
Old Mar 12, 2009 | 08:29 PM
thebleek's Avatar
thats him, not me
Old Mar 12, 2009 | 08:58 PM
Former User's Avatar
I mentioned in your original Idle thread that the problem is due to the fact that the original OEM brake booster hose has a check valve incorporated into it whereas the new replacement hose does not.
Old Mar 12, 2009 | 09:00 PM
thebleek's Avatar
/thread
thank you. I made another thread because I was worried this could be dangerous
hefftone79
Sep 18, 2011 08:51 PM
pmrider
Jul 9, 2009 09:45 AM
Cambocheen!
Mar 23, 2009 12:09 PM
lude98SH
Jan 24, 2006 03:39 PM
iwannaboostmyteg
Feb 7, 2004 10:43 AM
