alternator plug help
Old Mar 12, 2009 | 03:14 PM
chillz03's Avatar
Default alternator plug help
hi i have a 93 civic with a ls/vtec setup but i got a new jdm b18b block form the internet that came with the rounded square plug it only had 3 wires but it looked like it had a forth that was pulled out and i have the round 4 wire i just want to know if i get anther plug like the one i got on the b18b block can i match up the wire colors and use that plug and alternator. THX FOR THE HELP
both plugs had wire colors
wht/gre(this is the one the b18b was missing that looked liked it was pulled out)
wht/red
wht/blu
blk/yel
Old Mar 12, 2009 | 07:10 PM
CivicSpoon's Avatar
Default Re: alternator plug help
That's an alternator plug, not distributor. Since you have a JDM engine, I'm assuming your using your stock engine harness (round plug), since the JDM harness is backwards. So you have a couple options. You could rewire the plug (put the square plug on the stock harness), you could buy an OBD1 B-series alternator, or you could swap the voltage regulator (part with the plug) from your stock original alternator into the housing of the new alternator.
Old Mar 12, 2009 | 07:21 PM
chillz03's Avatar
ya i know i dont know what i was thinking when i typed this up i fixed tho
i was planing on useing my OBD1 harness and the jdm plug but will the wire colors be the same just match them up?
Old Mar 12, 2009 | 07:29 PM
CivicSpoon's Avatar
Yup, the wires will match right up. It's only the shape of the plug that's different.
Old Mar 12, 2009 | 08:01 PM
chillz03's Avatar
oh ok thx you
deguzmanEG
Apr 18, 2010 05:00 PM
Jaker
Jun 14, 2006 07:22 PM
BlueShadow
Aug 2, 2004 12:36 PM
CrxSi10
May 5, 2002 12:40 AM
