CRX OEM foglight questions
Old Mar 12, 2009 | 03:14 PM
HondaJack's Avatar
Default CRX OEM foglight questions
I have a 91 HF with Factory Foglights (also factory armrest and rear louvers) but I need to get the lights out to clean them up and replace the bulbs.
Do I have to pull the bumper to get them out?
Anyone have a writeup on how to get them out? Of course it is not in the Crappy Haynes manual.
Thanks in advance for any help.
Old Mar 12, 2009 | 03:17 PM
kid-honda's Avatar
Default Re: CRX OEM foglight questions
No just remove the bumper blinker and you will see a bolt that attaches the light to the bracket.
BTW thats pretty sweet you got all that good stuff on one car.
Old Mar 12, 2009 | 03:18 PM
crx_si-r's Avatar
on my 91 dx I don't have to remove anything to take off my oem foglights. But then again my bumper support is different than yours. Are you using usdm or jdm brackets?
Old Mar 12, 2009 | 03:19 PM
Turbo Dan's Avatar
i have the jdm sir front end with fog lights and for me to remove the fog lights all i have to do is remove the bumper lens and that will let me unbolt the foglight from the bracket and pull out the light.
for you i'm almost positive it is the same workflow, because when you have the bumper off the workflow is to install the bumper and THEN install the fog lights last so there is no way you can pull off the bumper without first removing the fog lights.
edit, wow i must be slow at typing to be beat by two replies
Old Mar 12, 2009 | 03:24 PM
HondaJack's Avatar
Ahhhh I should have thought of that. Thanks. I am not sure of the options available for the 91 HF. I also got the double din radio and clock. Not sure about the clock but I had one with out it.
Old Mar 12, 2009 | 03:26 PM
HondaJack's Avatar
I didnt take off the bumper yet. I figured it couldnt be THAT hard so I gave up first. That and I was at work.
da9blk1
11
Sep 22, 2012 10:57 AM
Dazer 1991
Aug 14, 2012 11:32 PM
kingcobra
Feb 12, 2012 08:33 PM
bryant
23
Sep 15, 2003 10:54 AM
